Activity Forums Apple Final Cut Pro Legacy Mystery FCP 7 Spinning Wheel of death upon play
  • Mystery FCP 7 Spinning Wheel of death upon play
    Posted by Michael Harrington on August 9, 2014 at 9:19 pm
    I’ve been editing along for several weeks with few problems on my trusty MacPro FCP7 OSX 10.8.5 till now.
    I’m editing with a significant amount of footage, 7 cameras, 6 GoPro all converted to ProRes LT 1920×1080 59.94. Today I open project/sequence and when I press play it’s the spinning beach ball for 5-6sec or 30-40sec before it plays, if I press stop, then play its the same scenario. If I drag the cursor up/down the lengthy and complex time line no problem, as soon as I stop then hit play it’s the beach ball again. WTF…
    I actually had a similar problem a while back and discovered I needed an update to my Matrox MXO2 MAX and confirmed I currently have correct driver. I’ve talked with GTech to make sure no issues with my GSpeedes Raid 5 set up. I’m using Memory Cleaner to see how my memory is allocated and all looks good.
    I do not have any Stills in the project or timeline so CYMK issues are not a concern.
    I trashed prefs, repaired disk permissions, researched solutions, crossed my fingers and prayed to the edit gods, no solution yet. Any thoughts or trouble shooting tips will be appreciated.
    Thank You,
    Michael Harrington
    Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Mavrick, ATI Radeon HD 4870, 30-inch Cine Display, 4 – 1TB internal, G Speed 6TB Raid 5, 1.25TB Esata, Numerous FW 800 external drives, Matrox MX02Max, FSI 17″ Broadcast Monitor, Black Magic Mini Sync Generator, Mackie 1402 & Event 20/20 monitors.
    Amy Wilson replied 11 years, 4 months ago 2 Members · 2 Replies
  • Michael Harrington
    August 9, 2014 at 9:45 pm
    BTW, my profile say Maverick, I’m on another patrician with the specs I gave in my post. I do not have any FW drives hooked up and I’ve unplugged my Matrox as I trouble shoot problem.
    Michael Harrington
  • Amy Wilson
    May 5, 2015 at 12:29 pm
    Any luck with solving this? I’m having a similar issue in FCP 7 and using Matrox MX02 LE. Just updated to most recent driver for my OS (Lion) and maybe only a slight improvement, if any.
