Activity Forums Apple Final Cut Pro Legacy mysteriously unrendered frames
  • mysteriously unrendered frames
    Posted by Shayne Weyker on November 24, 2006 at 4:18 am
    I have a 90 second DV sequence I’m working on in FCP 5.11 for delivery on the web. I’m using a MacPro.
    My problem is a few of these these blue frames withthe word “unrendered” that appear in the exported versions of the video. But not in the canvas. I guess hooking my TV and DV converter back up will let me catch these frames when watching previews (right?) but I still need to know why the frames aren’t rendering.
    I have . . .
    trashed my preferences
    rendered everything before export (though not mixed down audio, there’s 4 tracks)
    looked for (and not found) track gaps on the main video track either with Shift-G or by eyeballing the timeline with max zoom where the unrendered frames are.
    In case it matters, one such unrendered frame is between a clip and a freeze frame clip that follows it. I also had the issue just after a .mov clip orignally exported from livetype and just before the clip that follows it.
    –Shayne
    David Battistella replied 19 years, 9 months ago 2 Members · 1 Reply
  • David Battistella
    November 24, 2006 at 3:45 pm
    Shane,
    Try the following
    select all in the timeline window
    IN the Sequence menu under RENDER make sure that all of the types of renders are checked.
    Then select either Command R or Option R to render the entire sequence.
    If you zoom the timeline into the frames and use the arrow key to advance a frame at a time I am sure you will find those unrendered frames.
    David
    Peace and Love 🙂
