Activity Forums Adobe Photoshop Mysterious non existent layer showing in file
  • Mysterious non existent layer showing in file
    Posted by Timi Boose on February 4, 2016 at 6:06 am
    Hi – I’m working on a cd digipack. There are quite a bit of layers. The back cover is a cityscape and should match the same coloring as the front cover – it is one photo laid across front and back. For some reason on the back cover, the coloring is completely different – it is all red – making it look like some kind of effect was applied. I have gone through all the layers and it never disappears. Sometimes I open the file and the effect is not there but sometimes I open it and it’s there. I am worried because i’m doing this for a client and need to send it to print. Is the file corrupted? What can i do to make it go away?
    Here is a photo and some screenshots of my layers. I noticed that at the top the layer style is set on “pass through” and before posting this, I changed that to normal and it made no difference.
    Any ideas?
    Any ideas?
    Timi Boose replied 10 years, 2 months ago 1 Member · 2 Replies
  • Timi Boose
    February 4, 2016 at 7:42 am
    If i turn all the layers with the background picture OFF, I still see that red image….
  • Timi Boose
    February 4, 2016 at 10:24 am
    Relief! I found out the answer searching on the internet. If this happens to you check your Channels window. I had a quick mask in the channels – how it happened i’ve no clue but i trashed it and my file is back to normal!!
