Activity Forums VEGAS Pro My videos are laggy and blurry after rendering
  • My videos are laggy and blurry after rendering
    Posted by Santeri Hulkko on July 16, 2017 at 6:34 pm
    Hi!
    I and my friends filmed our holiday with different cameras and I decided to make compilation type of video. I rendered the video with 60fps fullhd render settings and one of the clips looked blurry and kinda laggy while other videos looked fine.
    I watched the clip using VLC media player it looked nice and it also looked fine in vegas preview but when I rendered the clip it looked blurry and laggy.
    Resample was disabled
    Recorded: .mts AVCHD 60fps
    A comparison of two videos.
    https://youtu.be/ujzuRwvycPY
    (And I know, video was shaky as hell but i chose it because the problem was best seen in this clip)
    I also tested other render settings but this is my mainly used settings.
    https://gyazo.com/3e71fe51f281cf90e596fa71f68c39d9
    Thanks for the help and sorry for bad english!
    Santeri Hulkko replied 9 years, 2 months ago 3 Members · 6 Replies
  • Francois Pénzes
    July 17, 2017 at 12:29 am
    Hi Santeri
    Can you post MediaInfo of your original file ?
    https://mediaarea.net/en/MediaInfo
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    \’\’When the cutting stops, the editing begins…\’\’
  • Santeri Hulkko
    July 17, 2017 at 10:44 am
    Thanks for quick reply
    There you go:
    https://gyazo.com/f3286ed423629db12befffd55a8e7861
  • Ole Kristiansen
    July 17, 2017 at 3:21 pm
    Hi
    Your footage is:
    Framerate: 25 fps
    Scan type, store metod: Separated fields
    Scan order: Top field first
    Why do you render at 60 fps ?
  • Santeri Hulkko
    July 17, 2017 at 10:56 pm
    Hi!
    This footage doesn’t look that it was shot at 25fps and. When I preview that clip in VLC, it looks so smooth and that is the weird thing. Also other clips, which were shot with 2 other cameras had also 60fps with no problems and that’s why i want to render at 60fps.
  • Francois Pénzes
    July 18, 2017 at 12:38 am
    Hey Santeri !
    I was wondering the same thing as Ole K.
    By the way, VLC is a packet-based media player.
    That is why it can play almost all video content. It can play almost anything, even if the files are damaged or incomplete.
    Don’t forget that VLC also has a built in feature that does caching in order to deliver the output at a steady rate.
    Never base the quality of your footage on the output from VLC.
    Don’t get me wrong, VLC is a great player, just not a good reference.
    Cheers !
  • Santeri Hulkko
    July 18, 2017 at 10:15 am
    Alright, thank you!
