Activity Forums Apple Final Cut Pro My Tipp of the day…exporting portions of a timeline
  • My Tipp of the day…exporting portions of a timeline
    Posted by Alban Egger on February 2, 2012 at 9:02 pm
    I got asked this lot and found a way: How do you export a portion of a timeline when there is no I/O to be set?
    Easy:
    1. Select “R” Tool.
    2. Choose the Region which you want exported. You can even start/end in the middle of a clip. The R tool in fact sets I and O.
    3. Once selected make this region a compound clip. Option-G
    4. Step into the Compound
    5. Export the Compound Timeline!!
    6. Step back out and break the Compound apart.
    Takes 5 seconds longer than in FCP7, but it works and since the COMMAND-E export is so much faster than FCP7 renders, it will be eventually be faster anyway…..
    Another way is always to Send to Compressor and set I/O there, but that takes much longer…..
    Steve Connor replied 14 years, 7 months ago 3 Members · 3 Replies
  • Tom Wolsky
    February 2, 2012 at 10:00 pm
    This doesn’t work for me. I can’t make a compound clip from part of a clip. Just beeps at me. If you open the compound clip in the timeline and export using Cmd-E, the application still exports the entire project that contains the compound clip.
    What version are you using? Exporting compound clips worked in the first version, but hasn’t subsequently.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Alban Egger
    February 3, 2012 at 7:15 am
    wow, you are right. I just showed this to a friend last week. Now in 10.0.3 this does´t work anymore.
    neither making a compound from parts of a clip nor the exporting of compounds alone.
    It goes so far, that you can´t make a compound of a region at all anymore. you have to select the clips with the “A” tool, not the “R” tool.
    hmm…sorry guys for the confusion. I didn´t expect the step back….
  • Steve Connor
    February 3, 2012 at 9:21 am
    [alban egger] “hmm…sorry guys for the confusion. I didn´t expect the step back….”
    We had this with FCP Legacy as well, they would fix and add new things in a release but break others.
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
