Activity › Forums › Maxon Cinema 4D › my texture paths won’t relink…. help!
  • my texture paths won’t relink…. help!
    Posted by Joe Carusoe on February 20, 2007 at 4:07 am
    i built a fairly complicated thing on one computer…. then i transferred everything over to a new computer.
    copied all my textures to a new folder and set it as a ‘texture path’ in preferences. yet none of the new textures are relinking… it gives a texture error when i try to render, and the material previews all show blank boxes.
    it’ll take hours to relink all the textures manually…. why won’t c4d search the new folder and find all the textures i put there?
    help!
    (thanks!)
    Adam Trachtenberg replied 19 years, 7 months ago 3 Members · 2 Replies
  • Mylenium
    February 20, 2007 at 7:04 am
    If your textures were in sub-folders, those would still have to have the same name on the other machine and be in the same place relative to the parent folder which you choose in the prefs.
    Mylenium
    [Pour Myl
  • Adam Trachtenberg
    February 22, 2007 at 6:12 am
    The solution would be to “Save as project” and then copy the whole project folder over to the other computer.
