Activity Forums Apple Final Cut Pro Legacy My text keeps shifting on the last frame of a dissolve
  • My text keeps shifting on the last frame of a dissolve
    Posted by Larry Rochman on July 30, 2009 at 7:48 pm
    I’m new to Final Cut and am having a problem with TEXT. After I create my text, I use the “Center” button and then use the wireframe to put my text into position. When I add a dissolve, my text makes a slight shift down on the last frame. If I don’t use the “Center” button and leave the text where it is, No Problem. My work around right now is to click the “Motion Blur” and that solves the problem. However, I then have to Re-render the whole piece.
    Any ideas what I should be doing??
    Chris Borjis replied 17 years, 1 month ago 3 Members · 6 Replies
  • Chris Borjis
    July 30, 2009 at 7:53 pm
    your rendering the green line right so it turns blue?
    this usually happens during real time but un-rendered situations.
  • Larry Rochman
    July 30, 2009 at 8:02 pm
    Yes..everything is fully rendered..
  • Colin Mcquillan
    July 30, 2009 at 8:33 pm
    Also, check your render settings. See if there is a check beside Full in both the render selection and render all settings.
    This is by default unchecked. Without this checked some transitions from gfx/test over video can seemingly jump a field during the transition
    Colin McQuillan
    Vancouver, B.C.
  • Larry Rochman
    July 30, 2009 at 9:00 pm
    Thanks Colin:
    That did it. Thanks for your help. We’ve knocking our heads trying to figure it out. All the best..L
  • Colin Mcquillan
    July 31, 2009 at 4:48 pm
    [Larry Rochman] “We’ve knocking our heads trying to figure it out. “
    I nearly knocked my forehead flat with this myself when I first came across the same issue a few years back….
    Don’t understand why this wouldn’t be default ON, especially in the render sequence setting. Either that or these GFX overlay dissolves should cause a green bar until fully rendered as they don’t playback seamlessly without a “full” render.
    Colin McQuillan
    Vancouver, B.C.
  • Chris Borjis
    July 31, 2009 at 10:56 pm
    me too.
    when I hit the render hot key, I mean render all.
    why the hell would I want anything less!??
