Activity › Forums › Adobe Illustrator › My small company develops various graphic projects
  • My small company develops various graphic projects
    Posted by Victòria Campaner on June 27, 2018 at 3:42 pm
    Several weeks ago we got huge offer. We have been working during all this time on it. Most of the work was passing in Adobe Illustrator CC. A day ago we stumbled on a complicated issue, our .ai file stopped correctly opening. Third time it was opened, but a half of the file was empty, we tried to repair ai file by different methods, but we couldn’t.
    Tyrell Foreman replied 8 years, 3 months ago 2 Members · 1 Reply
  • Tyrell Foreman
    June 30, 2018 at 4:55 pm
    Place the damaged Illustrator file in a new Illustrator file.
    In case the method in the following can’t help, one of ways below might assist
    https://helpx.adobe.com/illustrator/how-to/recover-files.html
    https://download.cnet.com/Recuva/3000-2242_4-10753287.html
    https://onlinefilerepair.com/en/illustrator-repair-online.html
    Important: This solution doesn’t work if you didn’t select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
    1. In Illustrator, choose File > New.
    2. Select the appropriate size and color mode, and then click OK.
    3. Choose File > Place.
    4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
    5. Name and save the file.
