Activity › Forums › Apple Final Cut Pro Legacy › My really frustrating install issue
  • My really frustrating install issue
    Posted by Bob Bonniol on September 15, 2006 at 8:48 pm
    Hi all… While I can;’t be described as a ‘calf’ with FCP, this issue has me stymied, and it qualifies as a basic question:
    We have 5 licenses of FCP around here. 3 are FC Creative SUites that were originally purchased as FCP HD 4.5 or 4.0, and then upgraded. Two are stand alone FCP installs, both FCP 5.0
    Recently a contract artist was hired at the same time we got a brand new quad G5. The guy installed his license of Shake, and for simplicity he also installed his license of FCP. We hadn’t yet bought a license for this machine. OK, fine. When he left, we wiped his apps off the machine by dragging them to the trash.
    In the mean time this quad did duty as an After Effects station for the most part. Finally I decided it was time to put an FCP install on it. So I bought an FCP suite to do just that…
    The computer installs only parts of the suite. FCP itself is ‘grayed out’ when I run the installer, and won’t install. The Soundtrack install claims I don’t have sufficient hardware (G4 processor or better, blah, blah… UH we’re trying to install on a quad G5 with 8 gigs of memory !). None of my other licenses will install either.
    Anybody have any ideas ? It ‘feels’ to me like my contract dude’s FCP license left behind some kind of system cookie thats making the machine think it already has FCP 5… Thats pure supposition.
    Any help MUCH appreciated. I’m getting tired of having to switch machines to run FCP when I have a fresh un-used license hanging around !
    Best,
    Bob Bonniol
    MODE Studios
    http://www.modestudios.com
    Contributing Editor, Entertainment Design Magazine
    Art of the Edit Forum Leader
    Live & Stage Event Forum Leader
    HD Forum Leader
    Todd Gillespie replied 20 years ago 3 Members · 3 Replies
  • Tom Meegan
    September 16, 2006 at 11:07 am
    Hi Bob,
    I haven’t dealt with your issue specifically, but here is the list of files I would look into.
    users//library/com.apple.FinalCutPro.plist
    users/
    /library/Final Cut Pro User Data/Final Cut Pro 5.0 Prefs.fcset
    users/
    /library/Final Cut Pro User Data/Final Cut Pro Obj Cache.fcmch
    users/
    /library/Final Cut Pro User Data/Final Cut Pro Prof Cache.fcmch
    Preference files to trash when there is app trouble – might be causing the problem;.
    root/library/preferences/com.apple.RegFinalCutStudio.plist
    I found this one while poking around, and I would bet this is causing the problem for you.
    root/library/application support/Final Cut Pro System Support
    Houses Custom Setting and Plug-ins. Probably not causing your issue.
    I am a bit parnoid, but I would copy these files to a removable drive,
    Eject the drive,
    Then trash the files individually followed by reboot.
    When the system wakes up, see if your installer works.
    Good luck.
    Tom Meegan
  • Bob Bonniol
    September 17, 2006 at 4:47 pm
    Tom,
    Thanks for the pointers… I’m going to give this a shot.
    Best Regards,
    Bob Bonniol
    MODE Studios
    HD Forum Leader
  • Todd Gillespie
    September 17, 2006 at 5:16 pm
    Hi Bob,
    Tom’s idea’s are good and you should try them. But I think the issue you’re having is related to the ‘recipts’ folder. I didn’t see it in Tom’s post-if so, you can ignore this post. An install program looks at the recipts folder to see what’s already install.
    I believe it’s in you Library FOlder on your HD-NOt you’re user Library. You’ll see a FCP recipts, DVD STudio Pro, as well as others, if you get them all, the next time you go to your installer none of them should be grayed-out.
    Good Luck,
    Todd at UCSB
    Television Production
