Activity Forums VEGAS Pro My project file wont open?
  • My project file wont open?
    Posted by Matt Gussin on May 26, 2010 at 10:00 pm
    Hey, I have spent a great deal of time with this project, having dealt with many Sony Vegas faults such as crashes, freezes, files, formats etc. However there was always a way round them. Yet now, when i load my project, it gets to 6& loaded, then a error message pops up saying
    ‘An error occurred during the current operation. An exception has occurred.
    Then if i click OK, it will close, if i click details this come up:
    ‘Vegas Movie Studio Platinum 9.0
    Version 9.0b (Build 92)
    Exception 0xC0000094 (integer divide by zero) IP:0x33A76729
    In Module ‘mcmp4plug.dll’ at Address 0x339A0000 + 0xD6729
    Thread: ProgMan ID=0xFA8 Stack=0x5DCE000-0x5DD0000
    Registers:
    EAX=00000000 CS=0023 EIP=33a76729 EFLGS=00010246
    EBX=0d0d3d0c SS=002b ESP=05dcee88 EBP=0d0d3c30
    ECX=00000000 DS=002b ESI=00000002 FS=0053
    EDX=00000000 ES=002b EDI=00000000 GS=002b
    Bytes at CS:EIP:
    33A76729: F7 F1 8B 44 24 0C F7 F1 …D: 8B C2 33 D2 4F 79 4E EB ..3.OyN.
    Stack Dump:
    05DCEE88: 00000000
    05DCEE8C: 0D0D3D0C 0CF60000 + 173D0C
    05DCEE90: 339B25E5 339A0000 + 125E5 (mcmp4plug.dll)
    05DCEE94: 00000002
    05DCEE98: 00000000
    05DCEE9C: 00000000
    05DCEEA0: 00000000
    05DCEEA4: 0D0D3D08 0CF60000 + 173D08
    05DCEEA8: 0D0D3D0C 0CF60000 + 173D0C
    05DCEEAC: 00000000
    05DCEEB0: 00000000
    05DCEEB4: 0D0D3C30 0CF60000 + 173C30
    05DCEEB8: 0D0D3C60 0CF60000 + 173C60
    05DCEEBC: 05DCF2F4 05CD0000 + FF2F4
    05DCEEC0: 00000000
    05DCEEC4: 00000000
    > 05DCEED0: 77DC3B23 77D90000 + 33B23 (ntdll.dll)
    > 05DCEEE0: 77DAF871 77D90000 + 1F871 (ntdll.dll)
    > 05DCEEE4: 778F0816 778E0000 + 10816 (KERNELBASE.dll)
    > 05DCEEF0: 778F0849 778E0000 + 10849 (KERNELBASE.dll)
    > 05DCEF40: 77915EB0 778E0000 + 35EB0 (KERNELBASE.dll)
    > 05DCEF4C: 778F0849 778E0000 + 10849 (KERNELBASE.dll)
    > 05DCEF50: 76001184 75FF0000 + 11184 (kernel32.dll)
    > 05DCEF5C: 339B2DF7 339A0000 + 12DF7 (mcmp4plug.dll)
    > 05DCEF94: 339B22B9 339A0000 + 122B9 (mcmp4plug.dll)
    > 05DCF000: 00C0BE43 00400000 + 80BE43 (VegasMovieStudioPE90.exe)
    05DCF004: 14F7A338 14850000 + 72A338
    05DCF008: 00000000
    05DCF00C: 3FF00000
    05DCF010: 0D1196D0 0CF60000 + 1B96D0
    > 05DCF038: 00480000 00400000 + 80000 (VegasMovieStudioPE90.exe)
    > 05DCF03C: 00480000 00400000 + 80000 (VegasMovieStudioPE90.exe)
    05DCF040: EB851EB8
    05DCF044: 404DF851
    > 05DCF048: 7602C019 75FF0000 + 3C019 (kernel32.dll)
    05DCF04C: 00002343
    > 05DCF0B4: 0055005C 00400000 + 15005C (VegasMovieStudioPE90.exe)
    > 05DCF0B8: 00650073 00400000 + 250073 (VegasMovieStudioPE90.exe)
    > 05DCF0BC: 00730072 00400000 + 330072 (VegasMovieStudioPE90.exe)
    05DCFFF0: 00000000
    05DCFFF4: 005282F0 00400000 + 1282F0 (VegasMovieStudioPE90.exe)
    05DCFFF8: 00AF3D58 00400000 + 6F3D58 (VegasMovieStudioPE90.exe)
    05DCFFFC: 00000000′
    WHAT CAN I DO? I HAVE SPENT AGES ON THIS PROJECT! ANY SUGGESTIONS, PLEASE!!!!
    John Rofrano replied 16 years, 3 months ago 4 Members · 4 Replies
  • John Rofrano
    May 27, 2010 at 12:50 pm
    Only Sony developers can decipher a program dump so you should definitely contact Sony.
    From what I can see, it’s dieing in a module called “mcmp4plug.dll” that may read MP4 files so I would say that there might be a piece of MPEG4 media on your timeline that is causing the problem. You might want to move some of the last MPEG4 files that you added to the project, into a new folder and tell Vegas to ignore missing files when it opens and see if you can get it to open that way. Then slowly move files back in until the project won’t open again. At that point, the last file you moved is most likely the problem.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Matt Gussin
    May 27, 2010 at 3:09 pm
    OK thanks, you have gave me an idea with your answer. Will this work?
    I convert all the mp4 files to a different format and then put them in the same location as the mp4 files (with same name, then get rid of mp4). Will that work?
    If so, what is the most Vegas friendly video format? i have had a lot of trouble with formats, so i started using mp4 and it was working fine until one random day, this happens.
  • Eleanor Trezise
    May 28, 2010 at 8:58 am
    I personally always use WMV or AVI, WMV being my preference. I never have any problems. If you convert the clips, giving them the same names as the mp4 files won’t work for replacing them because the extension is different; however, move the mp4 files from their current location(s) so that Vegas asks where they are. Then use the option to find the files yourself and simply select the wmv/avi files instead.
  • John Rofrano
    May 29, 2010 at 12:39 pm
    WMV is just as bad as MPEG4 when it comes to editing because it is a highly compressed delivery format and not an editing format. I would use AVI files with an intraframe codec. If you are working in SD just use DV AVI.
    ~jr
