Activity › Forums › Apple Final Cut Pro Legacy › My new Plugins are not working!!!
  • My new Plugins are not working!!!
    Posted by Chuck Purnell on August 13, 2009 at 4:27 pm
    I just downloaded some new plugins for FCP and everything installed successfully. I got the prompt on the screen that said so. I opened FCP and I saw my new plugins listed in the effects tab. I dragged one down to the time line onto a clip and rendered it out. When I played it back, I get a full screen watermark from the company that makes the plugin! Again the plugins ARE successfully installed. My plugin expires in 2011. This is NOT an expired trial version. The folder is in my Applications and not in my plugins folder.
    I tried dragging them to my Plugins folder to see if that was the problem and then opened FCP back up and it deleted all of them so I dragged them back to my applications folder and opened FCP back up and they have returned.
    I double clicked on the transition and the plugins parameters showed up for that plugin effect and i could adjust various settings. However the effect is still a black full screen water mark with the company’s name.
    I cannot get these plugins to work for nothing. They are compatible with Intel and PPC machines. I have a PPC G5. I am running Leopard 10.5.8 and FCP 6 all of which are compatible according to their system requirements.
    Cre8tive Minds Entertainment, LLC
    Steve Eisen replied 17 years, 1 month ago 4 Members · 5 Replies
  • Mark Maness
    August 13, 2009 at 4:29 pm
    You need to contact the company you bought the plugin. Its not an issue with FCP, unless you have installed FCS3. There may be some issues with plugins for a while until they all come to speed.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Chuck Purnell
    August 13, 2009 at 4:36 pm
    okay I am still using FCS 2.
  • John Fishback
    August 13, 2009 at 4:58 pm
    What plugins are you trying to install?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Chuck Purnell
    August 13, 2009 at 5:19 pm
    Genarts – Saphhire 2.05
  • Steve Eisen
    August 14, 2009 at 1:23 am
    Do you happen to have those same plugins installed on another one of your systems? I don’t believe Genarts allows you to do this.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
