My Movie Studio 15 crashes when I try to import videos
Posted by Gabriel Chang on June 27, 2019 at 5:33 pmA week after I used Movie Studio 15 I tried to import a video and it crashed. The codec of the video is the same I tried the video that I used last time it worked, I tried reinstalling the program and restarting the computer, but nothing worked.
Gabriel Chang replied 7 years, 3 months ago 3 Members · 10 Replies -
George Dean
June 27, 2019 at 9:39 pmHi Gabriel,
Can you provide more information?
– What build number of MS15
– Your system specs, drivers, and OS, including graphics card.
– Using the free app Mediainfo (in text mode) post a screenshot of the report Mediainfo gives of your source media.
– Try a full reset, while holding down the ‘Ctrl+Shift’ keys, double left click on the MS15 desktop shortcut. A small window should appear, check the box ‘Delete all cached application data’, the left click on ‘Yes’. This will reset all MS15 settings back to factory installation, and delete the pesky cached application data which sometimes will cause MS to do strange things. (BTW: Uninstalling and Re-installing MS does not delete this cached data).
– If you can upload a small sample, maybe a few seconds, of source media, here, others may be able to determine better the issue.Best Regards……George
Gabriel Chang
June 28, 2019 at 1:10 pmWindows 10 Home, Build 17763.557
MS15 Build 146
8.00 GB RAM
Intel CORE I3-6006U.
INTEL HD GRAPHICSMedia info:
General
Complete name : C:\Program Files\VEGAS\Movie Studio 15.0\MovieStudioHD150.exe
Format : MZ
Format profile : Executable / AMD x86-64
File size : 24.8 MiB
Encoded date : UTC 2018-11-01 14:37:08 -
George Dean
June 28, 2019 at 1:35 pmHi Gabriel,
Thank You for the information. The info from Mediainfo is the MS15 program file. We need the file specs info from your source media, the video file that you are trying to add to your Movie Studio project. Please post those specs.
Also, in MS15, before you add anything Go > Options > Preferences > Video tab and in the ‘GPU acceleration of video processing’ select ‘Off’, then ‘Apply’ then ‘OK’. Then shut down MS15, start it back up and try to add your source media. That may help.
Gabriel Chang
June 28, 2019 at 3:18 pmI’ve tried every single video that I have on my computer and none of them work, so I’m not sure that this will help
The video’s Media Info:
General
Complete name : C:\Users\gabri\Desktop\Untitled.mov
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/avc1)
File size : 676 KiB
Duration : 4 s 4 ms
Overall bit rate mode : Variable
Overall bit rate : 1 382 kb/s
Encoded date : UTC 2019-03-11 02:30:06
Tagged date : UTC 2019-03-11 02:30:06Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=3, N=25
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4 s 4 ms
Bit rate mode : Variable
Bit rate : 1 260 kb/s
Maximum bit rate : 16.0 Mb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.046
Stream size : 616 KiB (91%)
Language : English
mdhd_Duration : 4004
Codec configuration box : avcCAudio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 3 s 947 ms
Bit rate : 117 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 56.5 KiB (8%)
Language : English
Tagged date : UTC 2019-03-11 02:30:06 -
George Dean
June 28, 2019 at 3:49 pmHI Gabriel,
Sometimes we do ask questions that make no difference. Other times the questions we ask are to assure us we are not running a rabbit down the hole. So, I agree, the file specs you posted should not cause any problems loading.
Let’s go back to your opening thread statement…..MS15 worked when you originally installed it, and now using the same source media it fails. If you have performed a full reset (as I posted above) and that does not fix it, after the full reset do a complete uninstall and clean install. If that does not fix it, it may be something in your system has changed and causing the issue. That may be a Windows update especially the graphic driver may have been updated and MS15 doesn’t like it. In that case you may want to roll the graphic drivers back to the previous version as a trial to see if that helps.
If none of that leads to an improvement, you may want to consider downloading the free trial version of Magix Vegas Movie Studio 16 Platinum and see how it responds to loading your source video. Both MS15 and MS16 Platinum can be installed at the same time, they are independent of each other.
George Dean
June 28, 2019 at 10:57 pmDid you try the free trial of MS16 Platinum?
Graham Bernard
June 29, 2019 at 7:27 amHi Gabriel! OK, we gotta start somewhere a bit more basic. ???? how much free space do you have on your Laptop running the i3 CPU ? How many Hard Drives?
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Gabriel Chang
June 29, 2019 at 12:22 pmI have 2 one of which is unusable , the one that I use has 809 GB left
