Activity › Forums › Adobe After Effects › My Motion Path WILL NOT Show –
Posted by James Jewhurst on August 10, 2012 at 1:17 amFor the life of me, I don’t understand it. I have AFX CS6, and I have gone through edit>pref>general>display>all key frames… Also have gone through View>view options>and ticked off all boxes. But my motion path will not show after I’ve made a few keyframes.
Anybody know what I am missing?
Thanks for any and all help, Cheers!
Ramon Sandino replied 8 years, 9 months ago 4 Members · 5 Replies -
Roland R. kahlenberg
August 14, 2012 at 9:54 amWhich property are you animating and have you inadvertently switch off View Options for the Comp Panel (CTRL+SHIFT+H)?
HTH
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
James Jewhurst
August 14, 2012 at 1:02 pmNo, that wasn’t it. I learned that using a shape layer won’t show the motion path, although is it supposed to? I made a regular comp and the motion path showed up, but in the shape layer, it does not. Thanks for your reply!
August 17, 2012 at 3:33 amIf you animated the layer using the Position property then you should see its path in the Comp Panel. Check that you’re not using one of the Shape Layer’s built-in transform properties to animate – there is no visible path for those.
What you can do is to animate using a Null layer and then linking the Shape Layer’s built-in position to this Null with a simple Expression pick-whip.
HTH
Ryan Dawson
February 18, 2015 at 10:39 pmI know this is only like 2 years late, but I just ran into this, and wanted to post this in case anybody else came upon this thread looking for a possible solution.
My shape layer was in fact showing a path I just couldn’t see it. I was looking at the anchor point of the shape itself and not the layer. I had a really small circle I had zoomed in to animate. I inadvertently moved the circle to the position I wanted to start my animation, and then when I animated the layer, the circle was about 500 pixels off the layer anchor point. The circle was far enough off the motion path I just couldn’t see it on screen. Super derpy. That is all.
Ramon Sandino
December 1, 2017 at 12:53 amThis reply is also 2 years after yours, but I also ran into this issue and wanted to thank you for posting this. I’ve been looking for a solution for about 2 hours and just came accross your reply and it fixed it. I made an account just to thank both of you!
