Activity › Forums › Apple Final Cut Pro Legacy › my mac did a pc thing
  • my mac did a pc thing
    Posted by Baz Leffler on March 21, 2009 at 3:09 am
    I am now celebrating my second year as a mac convertee and just had a PC moment. I work hard at it every day using my octo core mac and FCP and churn out a lot of HD stuff but yesterday after completing another half hour episode of a series we make I went to the beginning of the timeline to do a final pass check and tweek before I sent it on to the producers for revisions.
    But all of a sudden, when playing the timeline it would occasionally freeze then skip (drop framing playback) so I saved, closed FCP and reopened everything and it was still occuring. I thought “gee, where have I seen this before; not for a long time…. hey! but that was back in the good ole PC days.. now… what was my fix for that?” (sorry I always like to quote myself, especially when its a one man conversation…)
    So when this use to occur on the PC, I would just restart the ‘puter and away I went. NOW I find the same fix works for the mac; I must have totally overwhelmed the poor baby but now its back to its faultless self; onward and upward I say!
    Baz
    What would I do without the ‘UNDO’ button!!!!
    Colin Mcquillan replied 17 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • Colin Mcquillan
    March 21, 2009 at 3:41 am
    [Baz Leffler] “when playing the timeline it would occasionally freeze then skip (drop framing playback) so I saved, closed FCP and reopened everything and it was still occuring”
    I’ve had this happen to me as-well. For me it happens only after I have been running for a couple hours, and only when running media run through my e-Sata card and I’ve been running a few different apps simultaneously (ie: FCP, Safari, Fetch, Motion, so on..)
    Likewise for yourself, only a re-boot cures the problem.
    Is your media coming in through an e-Sata or fiber card?
    I have an internal media drive as well as my e-Sata raids, and I’ve never had this issue when working from the internal drive, only the e-Sata card, wether it be the RAID, or single e-sata drive.
    Colin McQuillan
    Vancouver, B.C.
  • Baz Leffler
    March 21, 2009 at 4:31 am
    [Colin McQuillan] “Is your media coming in through an e-Sata or fiber card?”
    Yes I have a Rocketraid 2322 connected to an external Mini-sas 8 TB raid array running raid 5. So maybe that is going to sleep a little bit do you think?
    Baz
  • Alexander Kallas
    March 21, 2009 at 5:32 am
    Repair permissions, and run DiskWarrior.
    Cheers
    Alexander
  • Rafael Amador
    March 21, 2009 at 7:09 am
    Again with Alexander.
    Baz, get your self Diskwarrior TechTools or Driver Wizar.
    You will change your signature;
    What would I do without DiskWarrior or the ‘UNDO’ button!!!!
    Cheers,
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Baz Leffler
    March 21, 2009 at 7:53 am
    Funny thing is… I HAVE DISK WARRIOR!!!
  • Thaxter Clavemarlton
    March 21, 2009 at 11:55 am
    [Baz Leffler] “But all of a sudden, when playing the timeline it would occasionally freeze then skip”
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
  • Colin Mcquillan
    March 21, 2009 at 7:41 pm
    [Baz Leffler] “So maybe that is going to sleep a little bit do you think? “
    Could be. I’m running the g=tech card that ships with the G-Speed eS. My system is set to never sleep though.
    Colin McQuillan
    Vancouver, B.C.
  • Colin Mcquillan
    March 21, 2009 at 7:44 pm
    [Alexander Kallas] “Repair permissions, and run DiskWarrior.”
    Have done both when I first noticed the trouble. Neither have worked on my system.
    Once I wrap my current projects I plan on rebuilding my system from the ground up. Hopefully that will wrench out the gremlins.
    Colin McQuillan
    Vancouver, B.C.
  • Colin Mcquillan
    March 21, 2009 at 7:49 pm
    [Thax Clave] “You should “Mixdown” the Audio for playback before you dub out of FCP”
    This is something I always do before laying to tape. Unfortunately, with this particular stuttering media issue, it doesn’t help.
    My best guess is the trouble lies with the raid card, or how the system is communicating with the card, as I’ve never had this issue pop up when working from my internal media drive, just my RAIDs and external e-Sata drives.
    Colin McQuillan
    Vancouver, B.C.
