Activity Forums Apple Final Cut Pro Legacy My LAcie HArd Disks Stop
  • My LAcie HArd Disks Stop
    Posted by Rajarshi Basu on August 21, 2008 at 1:34 pm
    I have 3 LAcies 500gb each connected to my MacPro on FireWire 800…I am editing a 120min documentary…but while i am playing my timeline….the disks that are not in use… go idle …and i get a dropped frame e warning.
    Is there anyway to remedy this ?
    Raj
    Jason Porthouse replied 18 years ago 4 Members · 4 Replies
  • Walter Biscardi
    August 21, 2008 at 1:55 pm
    System Prefs > Energy Saver > Turn OFF put hard drives to sleep when possible. Turn off anything to do with putting drives to sleep.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Rajarshi Basu
    August 21, 2008 at 2:00 pm
    Thanks a lot man…solved the problem !!!
  • Phil Holbrook
    August 21, 2008 at 2:02 pm
    I would double check your system preferences. Go into energy saver and make sure to uncheck the box that says “Put the hard drive(s) to sleep when possible.
    Phil
    Just like you remember it…
    maybe better.
  • Jason Porthouse
    August 22, 2008 at 1:03 pm
    THIS will do the trick nicely…
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
