Activity › Forums › Compression Techniques › My Head Hurts…
  • My Head Hurts…
    Posted by Mick Haensler on July 30, 2008 at 9:17 pm
    After extensive testing and hours of forum and web searches, I still haven’t been able to upload what I consider to be a good looking clip to Vimeo. I know it can be done because I’ve seen some fine stuff. I’ve got a major web site upgrade in the works right now and I need to know how to do this. My test clip is DV16x9, 8 minutes long. So far I’ve gotten so so results using a combo of FCP and Compressor. I’ve tried every setting I know and still don’t have what I’m looking for. any help would be GREATLY appreciated. Thanks in advance.
    Mick Haensler
    Higher Ground Media
    Jimena Aznar replied 15 years, 11 months ago 6 Members · 16 Replies
  • 16 Replies
  • Daniel Low
    July 31, 2008 at 9:39 am
    Mick,
    It would really help us if you detailed EXACTLY what settings & workflow produced the best results so far, at least then we’ll have a starting block to work from to improve things.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Mick Haensler
    July 31, 2008 at 1:49 pm
    Sure Daniel
    – Export movie as QT mov file using current settings
    – Take that file into Compressor
    – Choose QT7 compatible H.264 800Kbps Streaming setting
    – In Geometry tab, change frame size to 16:9 custom (320×180)
    In Settings
    – Frame Rate is current
    – Key Frames automatic
    – Data rate is automatic
    – Encoding is High Quality multi pass
    – Streaming is hinted streaming
    – No padding
    – Pixel depth 24
    – Spatial quality 50
    – Min. Spatial quality 50
    – Key frame interval 150
    – Temporal quality 50
    – Min. temporal quality 50
    – Average and Max data rate 0.688
    – Hinted for QT streaming server
    If there is anything I’ve missed let me know. TIA
    Mick Haensler
    Higher Ground Media
  • Daniel Low
    July 31, 2008 at 2:20 pm
    I’m not sure why you are choosing a streaming setting but try these:
    Export as you have already done:
    In compressor:
    Choose H.264 download
    Current frame rate
    framesize 640×360
    Keyframes – some say every 30 (or 25 for PAL) some say every 150 while others say 10x your source frame rate….so for NTSC that would be every 300. – Experiment..
    Datarate 1800Kb/sec
    Deinterlace using compressors frame control settings not the deinterlace filter. If you choose one of the complicated settings like Motion Adaptive, be prepared to wait a while.
    Audio AAC
    Sample rate 44.1
    Datarate 128Kb/s
    Let us know how you get on..
  • Craig Seeman
    July 31, 2008 at 2:46 pm
    Vimeo’s own specs page suggest a key frame every 30 frames. That’s very frequent but if that’s the conclusion they’ve come to, it’s worth trying that. Since they’re re-compressing your upload to On2VP6 Flash they may have a reason for suggesting that.
  • Mick Haensler
    July 31, 2008 at 4:33 pm
    Thanks a boatload guys. I’m trying not to have to go to a third party piece of software to get “the best look in the world”(SNL short film reference). I’m away from the studio for a few days but will try all of the above and let you know what happened. I can’t thank you enough.
    THE COW ROCKS!!!
    Mick Haensler
    Higher Ground Media
  • Rich Rubasch
    August 2, 2008 at 3:14 am
    Whew! 1800 kbps seems way high to me. I don’t know what frame size Vimeo streams, but knowing that is key. 360 x 180 seems small but 640 x 360 seems too large for a decent looking clip in a pretty fast download.
    I almost always recommend changing the frame rate to 15 fps. This basically doubles your bitrate because you have half the frames to encode. Also, since it’s streaming, I almost always encode to mono. This way I can use a 64 kbps rate which is the 128 kbps stereo equivalent, again halving the datarate.
    Now your images looks good and it sounds good AND it streams fast.
    Win win.
    Rich Rubasch
    Tilt Media
  • Craig Seeman
    August 2, 2008 at 6:50 am
    Vimeo recommends 1800kbps for 640×480 video
    see
    https://www.vimeo.com/help/compression
    and 5000kbps for 1280×720
    Vimeo’s full screen unscaled video looks very good. They’re recompressing to On2VP6 so giving them more bits is a good thing given the additional round of compression.
    I’d almost never recommend 15fps unless one must use it due to some logistical reason and the source is very low motion (talking head interview). To me 15fps looks horrible. In addition at15fps the quality improvement per frame is not as great as you’d think (except in very low motion). The result is that there is greater temporal change between frames and the more movement between frames the greater the change. That’s going to make it “harder” on the codec.
  • Rich Rubasch
    August 4, 2008 at 2:17 am
    Take a look at our site at http://www.tiltmedia.com in the portfolio section. For me the most important thing is that a potential client won’t have to wait for a clip to play. We did a lot of experimenting, and we decided that the tradeoff between loadability and smooth playability (no starting and stopping, which FLV is prone to do on a 512 DSL connection) was worth it.
    Tell me if any of these clips don’t give you an EXACT idea of what we do at Tilt Media. That’s the point. Want to see full rez, high quality full motion and audio? Well, by that time I know you are interested and I can send you a DVD or set up a meeting.
    So, as part of my duties on the compression forum, I suggested that 15fps provides these benefits.
    I do agree that if you are delivering a clip that will be recompressed, then by all means, full frame rate and a higher bitrate.
    Rich Rubasch
    Tilt Media
  • Craig Seeman
    August 4, 2008 at 3:56 am
    [Rich Rubasch] “(no starting and stopping, which FLV is prone to do on a 512 DSL connection) was worth it. “
    Hmm, maybe my perception is colored by my market. In my neck of the woods bottom rung DSL is 768 and I don’t even think small businesses purchase speeds that low. More typical DSL in my area is 1500, 3000, 7000. Cable modem in my area ranges from 5000 to 30,000 (I have the later).
    15fps doesn’t bother me for the graphics but when I start seeing humans moving at that rate it’s just odd to me. The frame sizes are small to. I don’t mean this to be critical because you’re doing what you must if your target is 512 DSL.
    Vimeo is using somewhere around 1400 for their 720p24 delivery.
  • Daniel Low
    August 4, 2008 at 7:55 am
    Reducing the frame rate was something I used to do back in the days of dial-up. I’ve not needed to do it or advised anyone to do it for years (even for 3G streaming delivery to cell phones 5 years ago).
    Halving the frame rate typically reduces the datarate by only 30%, if that, and as Craig pointed out, halving the frame rate gives the codec a much harder job to do in the temporal domain and I’ve found usually has a pretty big hit on quality quality. With FLV I find making sure that the frame size is DIV 16 on both axis to be most important, something most people/services seem to forget.
