Activity Forums VEGAS Pro my hardware spec for sony vegas pro 11
  • my hardware spec for sony vegas pro 11
    Posted by Firdaus Aziz on December 11, 2011 at 4:13 pm
    CPU: AMD Phenom II X6 1100T
    Motherboard: GIGABYTE GA-970A-D3
    Memory: Kingston DDR3 PC1333 4GB
    HDD (os n software): Western Digital SATA3 (blue 16mb) 500GB
    HDD (files): 2 x Western Digital SATA3 Black Caviar 1TB
    Graphic Card: Saphire Radeon HD 6870
    Optical Disk Drive: Lite-On Blu Ray RW 12X
    Display: AOC 23″ LED E2351FH
    PSU: ACBEL R9 900W
    Keyboard & Mouse: Logitech MK200
    Speaker: Edifier R1900Tii
    Software:
    Windows 7 Pro 64bit
    Sony Vegas Pro 11
    Cineform Neoscene (is this a good investment?)
    Usage: 30 to 60 minutes program. Talkshow, travel log, weddings and documentary.
    Camera: Canon 5d Mark II or Canon Legria/Vixia HF G10
    Output: Not sure, any recommendation? I think the broadcast station has their requirement, I will get it as soon as i can.
    Future plan:
    Table: Wacom Bamboo Pen 4”x6” (CTL-460)
    Jog/Shuttle: Shuttle Pro v2
    Is this too much? Have I left out anything?
    John Rofrano replied 14 years, 9 months ago 4 Members · 6 Replies
  • John Rofrano
    December 11, 2011 at 4:58 pm
    You have a 6 core processor with only 4GB of memory. I would have at least 1GB for each core (so 6GB of memory minimum) but optimal is 2GB per core which would mean 12GB of memory.
    If you are doing work for broadcast I would add a Spyder 3 Pro to make sure your monitor is calibrated correctly monthly.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Firdaus Aziz
    December 12, 2011 at 1:21 am
    [John Rofrano] “You have a 6 core processor with only 4GB of memory. I would have at least 1GB for each core (so 6GB of memory minimum) but optimal is 2GB per core which would mean 12GB of memory.
    My mistake. It should have been –> Memory: 4 X Kingston DDR3 PC1333 4GB
    If you are doing work for broadcast I would add a Spyder 3 Pro to make sure your monitor is calibrated correctly monthly.”
    For monitor, can I just use a normal/consumer LCD TV for the moment and invest in a professional monitor later on? And will that Spyder 3 Pro calibrate a normal/consumer LCD TV as well?
    Thanks for your reply John.
  • John Rofrano
    December 12, 2011 at 5:53 pm
    [Firdaus Aziz] “For monitor, can I just use a normal/consumer LCD TV for the moment and invest in a professional monitor later on?”
    It doesn’t matter… it still needs to be calibrated. You will have much better luck calibrating a computer monitor than a consumer TV. Consumer TV’s will usually alter the image to make it “look better” which is *exactly* what you don’t want.
    [Firdaus Aziz] “And will that Spyder 3 Pro calibrate a normal/consumer LCD TV as well?”
    It depends on how you plan to connect it to your PC. If you are using a DVI connection then yes. If you are using HDMI out, probably not. I would check with DataColor support first.
    ~jr
  • Stephen Mann
    December 13, 2011 at 4:12 am
    I use the Color Munki Pro here because it will also calibrate my printer.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Ted Snow
    December 13, 2011 at 6:32 am
    [John Rofrano] “It depends on how you plan to connect it to your PC. If you are using a DVI connection then yes. If you are using HDMI out, probably not. I would check with DataColor support first.”
    John,
    Is it actually better to use the DVI connection rather than the HDMI connection coming out of the video card? I have an Nvidia 560Ti which has two DVIs and one HDMI out. Just curious if it’s better to use one over the other when using an LCD monitor.
    I just saw where B&H has the Spyder 3 Pro for $99.50 after rebate. Definitely worth looking into.
    ASUS P8P67 Deluxe MB
    EVGA GeForce GTX 560 Ti 1 GB DDR 5
    Intel i7 2600k 3.4 Ghz
    Corsair HX750 power supply
    Two Seagate Barracuda 500g SATA III drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Canopus ACEDVio card
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
    VEGAS 8.0
    VEGAS 11.0 32 & 64 bit
    Sony VX2100
    Sony HVR-Z7U
    Sony HDR-CX130
    Alesis HD24
  • John Rofrano
    December 14, 2011 at 12:05 am
    DVI and HDMI are basically the same digital signal. Ones and zeros are ones and zeros… no difference. I don’t know if the profiles that you can load into the video card affect the HDMI port. I know they affect the DVI port. My concern would be that the graphics card would somehow “enhance” the HDMI output which would be undesirable. If it doesn’t, then both connections should be the same.
    ~jr
