Activity › Forums › Adobe After Effects › My gradients are pixel-able.. how do i solve it?
  • My gradients are pixel-able.. how do i solve it?
    Posted by Leon Klein on February 18, 2010 at 5:17 am
    Hello
    I have some circular gradients i have made but i can always see the circular lines.. its not 100%
    gradient.
    I increase the bit depth in the project window but i still get the lines…
    whats the solution?
    thank you very much!
    leok
    Ben Mcallister replied 16 years, 7 months ago 4 Members · 3 Replies
  • Anthony Giola
    February 18, 2010 at 5:25 am
    Hello Leon,
    Do not take this for sure but i think you may be able to place a circular ellipse mask over the area of each of these pixel spots select Subtract as the transfer mode and then Feather out the mask until you have got it to be a bit more to your liking, you could do this with other mask shapes too just using elllipse as an example.
  • David Johnson
    February 18, 2010 at 12:57 pm
  • Ben Mcallister
    February 18, 2010 at 4:43 pm
    Hello Leon,
    This is called banding and believe me, I feel your pain.
    There are three ways you could address this problem.
    1. Try changing the bit depth in your project to 16bit color (but you have tried that already)
    2. If you are using a ramp effect, try increasing the ramp scatter which in effect adds a bit of noise to the gradient.
    3. You could also add another gradient under the first and offset a bit, i.e. move it so After Effects has more color to interpret. This brings me back to the first point. 8 bit color has 256 color increments to choose from so adding more data to process could thin out the banding effect.
    4. If all else fails, try adding some grain to your gradient and blurring it a little.
    These have all helped me in the pase.
    Hope this helps.
