Activity › Forums › Adobe After Effects Expressions › My first Script UI has a bug and its making me crazy
  • My first Script UI has a bug and its making me crazy
    Posted by Vincenzo Imbimbo on June 7, 2022 at 9:00 am
    Hello guys, i’ve just created an script UI and its working fine but every time i close After Effects and open it again the script stops working, it became like a shell, buttons without any functionality, and i only got 2 options to make it work again, 1: close the script and open it again. 2: change the working space to any other and go back to my working space where i have the script. Is this something related to the code of my script? or is a bug of After Effects?
    This is the main structure of my script, is anything wrong?
    { function myScript(thisObj){ function myScript_buildUI(thisObj){
    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "MyScriptName", undefined, {resizeable: true, closeButton:true});
    // Here goes the main function of the script //
    myPanel.layout.layout(true);
    return myPanel;
    var myScriptPal = myScript_buildUI(thisObj);
    if(myScriptPal != null && myScriptPal instanceof Window){
    myScriptPal.center();
    myScriptPal.show();
    myScript(this);
    Vincenzo Imbimbo replied 4 years, 3 months ago 2 Members · 2 Replies
  • Andrei Popa
    June 7, 2022 at 4:19 pm
    Maybe try to make it self invoking, like this
    (function myScript(thisObj) {
    function myScript_buildUI(thisObj) {
    var myPanel = thisObj instanceof Panel ? thisObj : new Window("palette", "MyScriptName", undefined, { resizeable: true, closeButton: true });
    return myPanel;
    if (myScriptPal != null && myScriptPal instanceof Window) {
    myScriptPal.show();
    })(this);
    I am not sure this will work. However, I have some advice for you. Use this webpage to make the UI. It’s by far the best and easiest way to create UI for After Effects
    ScriptUI Dialog Builder (joonas.me)
  • Vincenzo Imbimbo
    June 9, 2022 at 2:32 pm
    Thanks for your reply Andrei, unfortunately my script keeps having the same bug, I was hoping I wouldn’t have to rebuild everything from scratch but I’ll take a look at that ScriptUI Dialog Builder, thank you!!
