my files are too big
Posted by Donald Christensen on July 13, 2012 at 9:57 amMy setting are wrong. I am making a movie for youtube. The quality does not need to be high.
I’m rendering it as avi
the file is still too big. I assume I need to change
options, preferences but then what do I change?Roger Bansemer replied 14 years, 2 months ago 4 Members · 9 Replies -
Roger Bansemer
July 13, 2012 at 12:35 pmI’m using the Sony AVC/MVC setting and then going to the custom setting and changing the bit rate to 4,000,000.
You can reduce that bit size even further if you like or use one of the other templates.Roger Bansemer
Steve Rhoden
July 13, 2012 at 1:04 pmWhat Roger mentioned is the best option to me for youtube
content….Anything im doing for (youtube, Vimeo, Client preview)
the Sony AVC format is what i continually use with no disappointment.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Donald Christensen
July 13, 2012 at 6:52 pmIm a beginner at vegas
What steps do I do to change it as you suggest?
Roger Bansemer
July 13, 2012 at 7:07 pmBelieve me, I know it’s confusing at first.
1. Drag your mouse over your video and hightlight everything you want to make a video of. (in Vegas language your video and what you have on the timeline is called a “project”
2. Go to “File” and then “Render as”
3. There you’ll find a box that says “Save as type:”
4. Select the one that says “Sony AVC/MVC (mp4-m2ts.avc)
5. Just below it there is one that says “Template”
6. Click on that and you’ll get a drop down of templates. If you want a small sized video you can select one that says “internet 640×480 30p”
Experiment around a bit. Don’t use the 24p which is 24 frames per second. 30p is better which is 30 frames per second.7. If you want a larger video in HD you can use the “internet 1280×720 30p” but in that case you’ll need to go to the “custom” setting and change the bit rate to maybe 4,000,000.
Then give your video a file name and be sure you save it where you know it is.
Hope that helps.
Roger Bansemer
Donald Christensen
July 13, 2012 at 11:25 pmI don’t have those templates
I’m on vegas pro version 8
https://www.youtube.com/watch?v=oNMxIbrVCVw
Here is my movie. It’s an animation. as you can see I don’t need much in visual quality but I am going to add piano music.
I made each frame in 3d cad and the captions in Gimp
I have rendered this movie and the file size is good.(avi) I render it again and it is huge! (avi again) not sure what has changed.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Steve Rhoden
July 14, 2012 at 5:39 amI’m on vegas pro version 8
Should have mentioned this earlier…..Steve Rhoden
(Cow Leader)
1-876-832-4956 -
Donald Christensen
July 14, 2012 at 5:45 amSteve do you have those templates? How can I get them?
However after seeing my movie you may re-asses the format I should save in
Todd Boyle
July 16, 2012 at 8:12 pmI had good luck on Vegas 8, uploading videos to YouTube as WMVs.
Do what Roger and Steve said… “File- Render As- ” select WMV… pick a nice high bitrate at least 1 mbps. I seem to recall having to actually type in the bitrate I wanted…. it wasn’t on the list…
Roger Bansemer
July 16, 2012 at 8:18 pmThat’s right. The bit rates they have on the templates are in my opinion too high. You have to type something in there that suits your needs.
Roger Bansemer
