Activity Forums Apple Final Cut Pro Legacy My computer hangs when using FCP.
  • My computer hangs when using FCP.
    Posted by Ubermensch_6696 on February 19, 2007 at 6:46 am
    Hi.
    I just wanted to ask if anyone experienced anything of this kind.
    The problem occurs when I’m using FCP. Without any warning, my computer stops. The mouse doesn’t move, I can’t use the keyboard and I’m forced to reboot manually. This happens distrubingly often now (just this morning, it happened 6 times in the course of 2 hours.) That’s what prompted me to post about it now.
    There wasn’t any heavy compositing neither did I have a lot of layers. I’m handling NTSC footage and there aren’t filters that require rendering on the clips on the timeline – in some instances none at all. There are instances where simply playing a video clip on the viewer would lead to the computer hanging. It has also happened with only FCP open. I’d probably understand if I had every other programme open (i.e. if I was working on heavy compositing with AE) but I’m not and it shouldn’t really hang the way it does and with such frequency.
    It’s really irritating especially since I have directors and clients over to check on the projects we do for them. I’m hoping users on this forum can help. If other users have been unfortunate enough to experience this, what did you end up doing to solve the problem?
    Thanks.
    LES.
    MAC OS X
    ver. 10.4.8
    2 x 2.66G Dual Core Intel Xeon
    4G Memory
    FCP
    ver. 5.1.2
    Nathanh replied 19 years, 6 months ago 4 Members · 5 Replies
  • Patrick Kofler
    February 19, 2007 at 8:44 am
    Hi UEM,
    I’m experiencing the same problem. Expecially when positioning the cursor at the begginning of the timeline and then pushing play: complete freeze. The new system (new mac pro 2x3ghz, 6 gb ram, xserve raid and bmd decklink sp) seems really to be lot more unstable than the old g5 (with the same xserve raid and a bmd decklink extreme). To me this is disappointing. Is the system still so buggy?
    Patrick
  • Kaspar Kallas
    February 19, 2007 at 8:57 am
    I think BMD works with 3GB of RAM at the most righ now
    -Kaspar
  • Nathanh
    February 19, 2007 at 9:50 am
    Hi UEM & Patrick,
    When we first built up our Mac Pro to run FCP we didn’t follow Apple’s suggested ram configurations for optimal performance when running FCP, and we were having similar problems. Here’s a link to their suggested ram configurations for FCP:
    https://docs.info.apple.com/article.html?artnum=304492
    I’ve heard of others running different configurations than are listed in this document from apple, and having their machines work, but I know we had problems with our system until we followed these guidelines… then the system ran excellent. If your running the suggested ram configs, then ignore this, but if not, then give it a shot.
    Hope this helps.
    Best,
    Nathan
  • Patrick Kofler
    February 19, 2007 at 10:15 am
    Hi Nathan and Kaspar,
    thanks for your answers. I checked the ram configuration. I think it’s ok, but have a look at the screenshot (https://www.heliosvision.com/ram.tiff) and tell me, thank you. Concerning the bmd card, yes I read that. Now I’m trying to work in dv pal, avoiding the bmd card. Let’s see how long it works.
    Thanks Patrick
  • Nathanh
    February 19, 2007 at 7:52 pm
    Hi Patrick,
    I think your ram config looks safe. I also read the bmd decklink system requirements here:
    https://www.blackmagic-design.com/support/detail.asp?techID=60
    and I didn’t read about any 3 gig ram limit… but maybe there is some info on this somewhere else. However, they do reference Apple’s doc on FCP ram configurations used for best performance. Perhaps when running the BM Decklink, it needs to run with the ram in one of the listed configurations. Your system is closest to running the 4 gig configuration by removing all of your 512 dimms & leaving the 1gig dims in the current positions. That is how our Mac Pro is configured, and it runs like a champ, but we are running the AJA Kona 3 card. I think if your system continues to freeze while running FCP with the Decklink, it might be worth a try. Sorry I don’t have much info on the Decklink… I’m just going down the process of elimination. UEM is running his system with 4gigs of ram currently. If it is configured correctly, and he is still having the same issues, then it must be something else. UEM, your thoughts?
    Another thing you might try is trashing your FCP preferences. Here are some links for that:
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    https://fcprescue.andersholck.com/
    I haven’t heard of corrupted prefs causing the specific problem your having, but it has caused some other strange problems. Also worth giving a try.
    Best,
    Nathan
