Activity › Forums › Canon Cameras › My computer does’t recognize HV30
Posted by Marvin Chang on August 29, 2010 at 9:21 amMy window 7 computer doesn’t recognize my HV30 when I connect via USB cable. I changed USB cables, I changed to Apple computer, all didn’t work. What happened, anyone could help me?
Jeff surfrat Arganda replied 14 years, 6 months ago 4 Members · 7 Replies -
Brian Louis
August 29, 2010 at 7:15 pmIf you are trying to connect to download video you need to use firewire or HDMI capture, USB is for images.
Marvin Chang
August 30, 2010 at 5:31 pmThank you very much for your respond.
I tried HDMI connect from HV30 to my laptop, but again, my laptop didn’t recognized the HV30. Could you explain more detail on how to use HDMI connecting HV30 to computer? Thanks!
I didn’t have firewire, I will buy one if MDMI didn’t work.
Thanks a million.
Marvin Chang
August 30, 2010 at 5:40 pmThanks for your reply.
I tried to use HDMI connect HV30 to mu computer, but it didn’t recognize HV30. I don’t understand your term of “HDMI capture”? Can you explain more detail on how to connect HV30 to computer via HDMI cable. Thanks!
I don’t have firewire, but if that’s the only way, then I will buy one.
Thank you very much!
Brian Louis
August 30, 2010 at 8:32 pmLike I mentioned the HV30 only uses Firewire or HDMI for video transfer, most computers with HDMI ports are video out only ports, to capture via HDMI with a laptop you need a external device like a Matrox MX02mini(type 34 express card), a BlackMagic Design Intensity Pro Shuttle(USB3), or AJA io Express, these are not inexpensive solutions, the least expensive is firewire.
Bob Dix
September 2, 2010 at 10:35 amUse HDMI for transfer of HDV to Sony Bravia TV. Do not use HDMI to capture only Firewire IEEE 1394A card. We have been using it for 3 years, no problems. Black striping the tape for indexing may help. You should read instructions to set up in manual or ask Canon ?
You must save timeline at finish of transcode and type in project and click “SAVE” And wait, if you have set it to automatically to record. That happens after you have captured the video off the firewire.
Good luck…………
Freelance Imaging & Video
AUSTRALIA -
Brian Louis
September 4, 2010 at 10:14 pm[Marvin Chang] “I tried to use HDMI connect HV30 to mu computer, but it didn’t recognize HV30.”
Like I said before, HDMI port on most computers is video out only for use with a tv or video monitor, to capture you need a firewire port or external device with HDMI input. -
March 26, 2012 at 6:24 pmMake sure you use firewire cable and also in Camera setting go to menu and select camera menu, scroll down to rec/In setup, then go to HD standard and make sure you have either DV (wide) or DV (Normal) Selected, other wise your computer will not detect it. Hope that helps.
