Activity › Forums › Adobe After Effects › my composition in the timeline extends beyond the visible part of the timeline a
  • my composition in the timeline extends beyond the visible part of the timeline a
    Posted by daisy naidu on June 29, 2022 at 1:24 pm
    so the after effects timeline panel shows about 30 seconds of any composition and to render the full/ entire composition,(which is more than 30 seconds) i will have to first determine the length of the composition or fit the entire composition within the visible limits of the timeline panel to set the render frame to the exact start and stop points and then render . but this is impossible in my timeline as the panel shows only 30 secs of the comp, then when i scroll the comp to the left , i can see the remaining comp. now when i render im only able to render 30 secs (visible part of the timeline) and the remaining part of the composition which is hidden in the scrollable part is not getting rendered. please can someone tell me how i can fit my entire comp( start to stop) in the visible area of the timeline. in a sense how to zoom out of the entire composition to see the entire composition in the visible part of the timeline.
    im even unable to stretch the render frame beyond the visible part of the timetline( ie the part that gets hidden and revealed only when it is scrolled.)
    im using “Add to render que” .
    when i mean visible part of the timeline , it is the part that is in the panel by default 0 to 30 sec, the remaining part exists when the timeline is scrolled
    im new to AE, any help appreciated
    Nick Hill replied 4 years, 3 months ago 2 Members · 1 Reply
  • Nick Hill
    June 29, 2022 at 1:27 pm
    Press Ctrl+K which will open up the composition settings window. You can now set the duration of the comp to something that’s long enough to fit in the entire clip.
