Activity › Forums › Apple Final Cut Pro Legacy › my audio problem
my audio problem
Posted by Sergio Deustua on February 7, 2006 at 4:24 pmthe problem is that audio was recorded with timecode frame rate at 25. Video is on panasonic high definition, so audio must be in 29,97. How can i convert 25 to 29,97?
Sergio Deustua replied 20 years, 7 months ago 2 Members · 4 Replies -
David Battistella
February 7, 2006 at 4:35 pmset up a compressor preset.
make the preset 48K 29.97 and set all of your resampling to the highest quality.
I would do a few tests to see if your clips sync-up. with this method you will have to hand sync every single clip.
Was the audio double recorded to the camera as a bakck up?
This is an egregious error if the picture was not also recorded at this frame rate.
David
Peace and Love 🙂
Sergio Deustua
February 7, 2006 at 5:18 pmthank you david.
please forgive my ignorance. How do I set up a compressor preset? As you can see I -
David Battistella
February 7, 2006 at 9:41 pmopen compessor,
create a new preset that is 48K and 29.97 and batch the audio files.
it is not a thing I can take you through step by step if you do not have a basic knowledge of batch compressing.
David
Peace and Love 🙂
