Activity Forums Adobe After Effects My AE 6.5 wont load mpeg2’s
  • My AE 6.5 wont load mpeg2’s
    Posted by Paul Parnell on March 5, 2008 at 5:52 pm
    I’ve tried converting it to mpeg1, and mediaplayer files.
    I get the
    After Effects AEG plugin AFF: Error during parscing.(5027::12)
    I know there has to be a way to fix this, please help.
    Paul
    Paul Parnell replied 18 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Steve Roberts
    March 5, 2008 at 7:00 pm
    Neither one of those formats is a good choice. Try converting to Quicktime Animation, PNG, or Photo-JPEG.
  • Paul Parnell
    March 5, 2008 at 7:36 pm
    I’m capturing it in Premire Elements and it comes in as mpeg2 I’d like to keep it that if it will work. All thought any other high rez format will work.
  • Steve Roberts
    March 5, 2008 at 9:01 pm
    AE doesn’t like interframe-compressed formats such as MPEG-types and other delivery formats. Use the formats I mentioned.
  • Paul Parnell
    March 5, 2008 at 10:13 pm
    I tried converting it to .mov but the quility sucks and it still wouldn’t import it.
  • Paul Parnell
    March 5, 2008 at 10:50 pm
    I tried converting it in many ways but I keep getting errors.
    This time,
    After Effects error: retriving frame from video stream
  • Rhett Robinson
    March 6, 2008 at 1:50 pm
    Hi Paul,
    Why MPEG2? Is your camera capturing onto a a mini-DVD or something? Although a few applications will work reasonably well with that type of format (usually just cuts to prevent further degradation, like VideoReDo), Steve is right, AE doesn’t like that at all, as it’s usually a final format, output for DVD, not for working. MPEG is very lossy, and is a complicated stream that doesn’t work well for editing, and will have to re-encode if you do anything. Depending on what you’re wanting to do, you may want to make a proxy of the movie to import to AE, make your animation, and import into Premiere. In the future, you should have a conversion into one of the formats Steve mentioned, or read up on some of the different codec/compression formats. A good “quickstart” is watching Aharon’s tutorial on compression.
  • Paul Parnell
    March 6, 2008 at 2:02 pm
    This sounds good in theroy, but even when I change the format it gives me errors. The footage works fine in Elements, but not in AE. I want to change the footage, got any ideas on how to do it without loosing any quility, and it working. Which of course is also important.
    Paul
  • Paul Parnell
    March 7, 2008 at 12:02 am
    Thanks, I actually just started screwing with it. Your right though and I thank you for your help.
    Paul
