Activity › Forums › Apple Final Cut Pro Legacy › My 720p Drop Frame workaround
  • My 720p Drop Frame workaround
    Posted by Ansillary Changes on July 11, 2006 at 3:53 pm
    Hello everyone. I also have found my own little Final Cut Pro work around that I use to get around not having the option of a Drop Frame 720p 59.94 timeline. I am interested to know if anyone else has tried to following method.
    I conform several HD shows a month that are brought in from D-5 using the DVCPRO HD 720p60 codec. When I setup a sequence, I choose the DVCPRO HD 720p60 timeline setting, and go into the sequence settings. In the General settings tab, then change the Editing Timebase: from 59.94 to 29.97. Now when I go into the Timeline Options tab, the Drop Frame checkbox is no longer grayed out, and I can select it. I then hit OK, and drop my digitized show into the timeline. The footage goes unrendered, and you lose the control over seeing and stepping through each field, but once rendered everything is fine. I then output to a Panasonic 1700A (the 1200A was a nightmare!) Drop Frame time code accurate to a DVCPROHD tape at 720p. Once in a while I will have an issue where the the bars and tone may come in a field early. For example, sometimes my bars may come up on the second field of 00:58:39;29, insteading of coming up at 00:58:40:00 exactly. Sometimes it comes up a whole frame early, its not consistent or accurate everytime so I often run an assemble a few times and cancel out right after the bars as a test just to see where the bars come up, and then run the full show. This has been working out for me okay and none of my outputs have been rejected by the networks so far. I was wondering if anyone else has used this method as a workaround, or if anyone had any comments or questions. I would love to hear from you guys!
    -AC
    Walter Biscardi replied 20 years, 2 months ago 2 Members · 1 Reply
  • Walter Biscardi
    July 11, 2006 at 6:45 pm
    I use the 1200A and simply Advance the entire timeline by 20 frames in Final Cut Pro, but set in-point in both FCP and the deck to 59;00;00 even. Works everytime. Bars and the show start accurately. We’ve delivered 30 episodes so far to the networks and all is well.
    Walter Biscardi, Jr.
