Activity › Forums › Adobe After Effects › my 1080i footage lost weight
  • my 1080i footage lost weight
    Posted by Janson Williams on March 25, 2009 at 3:38 am
    Hello, very new to AE and its interface but not so new to motion effects. My question is when I import at clip of 1440×1080, it looks squished width wise. When I upload normal DV size footage, all looks well. I have looked all over composition settings, and change different items many of times to see if anything changes, when i view tutorials and people import 1920×1080 footage, all looks well. I’m hoping its some setting im over looking as im sure AE works will all HD aspect ratios.
    Any help is appreciated.
    Thanks for reading.
    Janson Williams
    Janson Williams replied 17 years, 6 months ago 2 Members · 4 Replies
  • Kevin Camp
    March 25, 2009 at 3:48 pm
    1440×1080 is a common hd resolution… it uses a pixel aspect ratio of 1.33 to get a 16×9 frame aspect ratio (much like dv 720×480 uses a .9 par to get a 4×3 ratio or widescreen sd 720×480 uses a 1.2 par to get a 16×9 ratio).
    to fix this, you can simply hit the pixel aspect ratio correction button at the bottom of the preview window… it’s the one that looks like a rectangle with an arrow above it.
    or, you can work in a square pixel comp (set the comp settings to 1920×1080, square pixel). ae will handle the pixel aspect ratio conversion from the sources par to the comp’s par, so you won’t need to scale anything.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Janson Williams
    March 25, 2009 at 5:40 pm
    Kevin,
    Thank you very much, is that button just for a preview? meaning, if i worked in AE with it the pixel aspect ratio toggled to square would it export as it looks in the preview window?
    Janson Williams
  • Kevin Camp
    March 25, 2009 at 6:32 pm
    yes… if you work in a 1440×1080 comp with a 1.33 par, then it will render as 1440×1080 with a 1.33 par.
    if your next step is to take that footage into a piece of software that works with typical video standards (like an nle) then it should be fine with that file (as it would have been if you took the raw file into the nle).
    if your next step is uploading to the web, a web player may not recognize the file as having a non-square pixel and may display it squished.
    so your workflow may depend on what the destination is, or more specifically, what the next step in your process is….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Janson Williams
    March 25, 2009 at 8:05 pm
    yes, absolutely, thank you again,
    im sure i will find out someday why there is that toggle button in AE for a specific purpose i might need someday
    thanks again for the info
    Janson Williams
