  • Posted by Nate Cranney on February 27, 2009 at 9:29 pm
    I need to take a FCP file and convert it into a jpeg 2000 and then wrap it in a MXF wrapper. I know how to convert into a jpeg 2000 file, however, I don’t know how to wrap it in a MXF wrapper. Any help would be appreciated. Thanks.
    Bjoern Adamski replied 16 years ago 4 Members · 6 Replies
  • Eric Peters
    February 27, 2009 at 11:25 pm
    If you have Sony’s XDCam Transfer software installed on your system, you should be able to easily export the MXF file that you need by going to File > Export > Sony XDCam in FCP.
  • Bjoern Adamski
    March 2, 2009 at 6:54 pm
    JPEG2000, not XDCAM.
    I am not aware of a software solution on the Mac that can wrap to MXF with JPEG2000 compression. I assume you need this for digital cinema. You should check DVS Clipster:
    https://www.dvs.de/products/video-systems/clipster/clipstersupregsup/clipstersupregsup-3g-and-dci-mastering.html
    Product Manager
    MXF4mac
    https://mxf4mac.com
  • Eric Peters
    March 2, 2009 at 7:05 pm
    My bad… You’re correct. Using the XDCam MXF export functionality allows for limited compression types. Taking a closer look, it does allow you to do more than just XDCam formats but not much more.
  • Nate Cranney
    March 13, 2009 at 9:54 pm
    Thanks for the tip. Clipster is a little out of the budget right now. Would Pronto work from the same company?
    -Nate
  • Ben Lawrence
    September 7, 2010 at 8:42 pm
    Did you ever find a workflow for wrapping JPEG 2000 files with an MXF wrapper? Much appreciated for your help.
  • Bjoern Adamski
    September 7, 2010 at 9:01 pm
    Yes, we are aware about various solutions and upcoming new ones. Feel free to contact us via mxf4mac.com/contact/
    Product Manager
    MXF4mac
    https://mxf4mac.com
