Activity Forums Adobe Premiere Pro MXF Won’t Import- CS5
  • MXF Won’t Import- CS5
    Posted by Rick Sullivan on November 17, 2011 at 5:15 pm
    I am acquiring some file video from a TV station and did a test to be sure their MXF files would import properly and work in my own system–PC, Premiere Pro CS5. It all went well… at first.
    I left my hard drive at the station to load up with video and have now retrieved it. None of this new footage will import into PP-CS5, nor into AE! The file extensions look identical to the test clips that still work just fine. What could be different? How Can I solve this?
    Rick Sullivan
    http://www.ricksullivanmedia.com
    Tim Kolb replied 14 years, 9 months ago 2 Members · 1 Reply
  • Tim Kolb
    November 18, 2011 at 6:02 pm
    It doesn’t sound like it’s your problem to solve.
    They sent you test files that worked…and the next files did not…have you inquired with them as to what’s different about the later files?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
