Activity › Forums › VEGAS Pro › MXF two channel audio
  • MXF two channel audio
    Posted by Aleksandrs Dubanevics on May 26, 2016 at 11:47 am
    Hi all,
    I have Sony Vegas Pro 12 and I’m trying to render an mxf file that would have only 2 audio channels. But when I choose 2 channels from the drop-down list, what I get is a file with 8 channels – 2 channels with sound (what I need), and 6 more silent channels (which I don’t need). What am I doing wrong? Can I do something about it – just to get my file without those 6 silent channels? Any help would be much appreciated.
    Many thanks!
    A.
    Aleksandrs Dubanevics replied 10 years, 4 months ago 2 Members · 6 Replies
  • Marco Baer
    May 26, 2016 at 4:11 pm
    Could you specify which kind of MXF is meant?
    There are some professional flavors of MXF which are standarized to a given count of audio channels and the Vegas renderer then only defines the mapping across the defined amount of audio channels.
  • Aleksandrs Dubanevics
    May 26, 2016 at 4:57 pm
    Well, I’m using PAL MPEG IMX 50 Widescreen template, just changing bitrate to 30 (CBR).
  • Marco Baer
    May 26, 2016 at 5:06 pm
    XDCAM IMX standard allows for either 4 channel audio, if audio is 48 kHz/24 bit, or 8 channel audio, if audio is 48 kHz/16 bit. There is no 2 channel IMX.
    May 26, 2016 at 5:33 pm
    Thank you! I was suspecting this… It’s just really strange that the TV station I need to send my file to asks specifically for IMX format (basically, they want an IMX30 625/50 (30Mb/s) compressor) and allows only 2 channel audio? Could it be that I choose the wrong template to render my file?
  • Marco Baer
    May 26, 2016 at 7:56 pm
    I would ask back to the TV station. I’d assume they mean what Vegas Pro does. Only channel 1 and 2 filled with audio. They can’t expect what isn’t possible and have to take XDCAM IMX as what it is.
    May 26, 2016 at 7:58 pm
    Thank you! That’s what I’m going to have to do.
