Activity Forums Compression Techniques MXF Op1a Wrapper no timecode in the MXF header
  • MXF Op1a Wrapper no timecode in the MXF header
    Posted by Charles Viau on August 22, 2011 at 4:12 pm
    I need to deliver a MXF Op1a Wrapper to a broadcaster
    i did my MXF via XDCAM export in FCP and i did one with Carbon Coder on pc.
    i tought everything was great till the broadcaster tell me:
    “”But it has no timecode in the MXF header so it won’t cue and play on the video servers (this is really important). It has timecode elsewhere in the package and can be edited (ideally this would not be there is it can confuse closed caption insertion – relevant if the program is in the library and is subsequently played to air when captioning””
    Ok, i will remove the timecode track in my Quicktime and re-encoding in mxf but …
    Im seaking a way to implement the header of the MXF to add that timecode field ???
    Anyone know the solution ?
    Charles Viau replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
