Activity Forums Adobe Premiere Pro MXF OP1A v Prores
  • MXF OP1A v Prores
    Posted by Roen Davis on August 23, 2014 at 10:17 pm
    Hi All,
    I am commencing a project where we have to choose between MXF OP1A mpg 2 @ 35MPS or Prores 422 HQ which seems to be about 180+ MPS. I am expecting the need to blow it up and composite some very old footage: should I push for Prores or accept the economists push for the cheaper MXF? My choice would be prores but maybe I am overlooking (am not so familiar with) MXF OP1A.
    to the deaf person the dancer appears mad
    Roen Davis replied 12 years ago 4 Members · 4 Replies
  • Erik Lindahl
    August 24, 2014 at 9:36 am
    What’s the original footage’s format / codec?
  • Dennis Radeke
    August 24, 2014 at 2:13 pm
    There is also XDCam 50 which is 4:2:2. It really comes down to a couple of factors:
    1 – drive space (prores will be significantly more). If that’s a problem, go with MXF OP1a
    2 – type of editing. Both codecs are good and you can ‘blow up’ XDCam reasonably well like ProRes though I’d give the quality advantage to ProRes (though I’ve not done any true testing) If you’re going to zoom in a lot (say 250% plus) I’d probably use ProRes.
    3 – speed of scrubbing vs. your system. If you have a newer system with lots of RAM and so forth, then go back to items #1,2. If you have a old system with mediocre ram, etc. then ProRes may provide a smoother editing experience.
    HTH,
    Dennis – Adobe guy
  • Ericbowen
    August 25, 2014 at 8:54 pm
    With that codec of OP1A Pro Res HQ would definitely look far better in the end. If they took DNxHD OP1A then that would be an equal option to Pro Res HQ though DNxHD as far as quality.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Roen Davis
    August 26, 2014 at 12:23 am
    Thanks for the response.
    The original is old film – circa 1914. We have the opportunity to get it done the way we like but there are competing points of view.
