Activity › Forums › Adobe Premiere Pro › MXF OP1a export for broadcast
  • MXF OP1a export for broadcast
    Posted by Nelson Ng on May 17, 2017 at 1:24 pm
    Hi, I have a project that I need to export for broadcast. As the schedule is quite tight, I would like to get it right on the first time. Can someone let me know what are the exact settings for the following requirements?
    Video:
    File Container – MXF OP1a (SMPTE 378M)
    Codec Sony – XDCAM HD422
    Chroma format – 4:2:2
    Bit Rate – 50mbps
    Display Resolution – 1920 x1080
    Frame rate – 25fps (501
    Scan Mode – Interace, top field first
    GOP – IBBP (Length: 12) – Sequence header on each GOP – First GOP closed
    Aspect Ratio 16:9
    Audio:
    Format – AES – 3 (SMPTE 382M)
    Audio Essences – 8
    Channel per essences – 1 (Mono)
    Sampling rate – 48Khz
    bit depth 24bit
    Dynamic Range – Between -20dbfs and -10 dbfa
    Loudness – Normalise at -21db
    Thanks a lot, much appreciated!
    Todd Perchert replied 9 years, 4 months ago 4 Members · 4 Replies
  • Daniel Waldron
    May 17, 2017 at 1:55 pm
    The video settings are pretty straight-forward. You should be able to set those in your export window. You’ll probably just want to make sure your chroma and luma levels are broadcast safe.
    Audio can be a little tricky. I would bring your final audio mix into Audition, so you can easily normalize the audio. I like to use the Match Loudness feature to automatically bring everything into the broadcast legal range. You’ll want to have a good sounding mix first though. You can use the Loudness Radar in Premiere or Audition to help adjust your mix manually. Keep in mind that with stereo exports, I believe Premiere may export 3db louder, so do a test export (you can check it with the Amplitude Statistics or Loudness Radar in Audition) and if that’s the case, just drop your levels -3db in Premiere and you should be good. Premiere also has a Loudness Normalization box in the export window, but I’ve had mixed results with that.
  • Nelson Ng
    May 17, 2017 at 2:02 pm
    Is there a specific preset for the video I should use?
    I wasnt sure what to put for
    And where I can change the Bit Rate
  • Tero Ahlfors
    May 17, 2017 at 3:30 pm
    MXF OP1a is a pretty strict codec. Pretty much the only setting you can change is whether the file is interlaced or progressive. You don’t need to bother with anything else.
  • Todd Perchert
    May 17, 2017 at 7:04 pm
    There are system presets for MXF OP1a in AME. Just scroll down to the one that matches your listed requirements. There’s an XDCAM 50mbps 25fps 1080 preset.
    TC
