Activity › Forums › Creative Community Conversations › MXF op-atom inconsitencies
  • MXF op-atom inconsitencies
    Posted by Trevor Asquerthian on December 10, 2014 at 5:44 pm
    Re-upped on the trial and updated to Pro Video 2.0 to access MXF.
    Importing MXF files from AvidMediaFiles folder…. results in all the atomised clips (i.e there are 8 audio track clips per video clip).
    I guess there is no easy way to group/merge these correctly?
    John Pale replied 11 years, 9 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    December 10, 2014 at 6:55 pm
    [Trevor Asquerthian] “I guess there is no easy way to group/merge these correctly?”
    Not directly with FCPX. You’d need an interchange FCPXML to be able to join the clips on import.
    There’s an app called “Atomic Fusion” that will join the atoms, and send it to FCP 7: https://hamburgpromedia.com/products/mxf4mac/applications/atomic-fusion.php
    but it was not updated for FCPX.
    Jeremy
  • John Pale
    December 10, 2014 at 6:56 pm
    That’s essentially the difference between Op1A and OPAtom. OpAtom has separate audio. That’s what Avid uses.
