Activity › Forums › VEGAS Pro › MXF in Vegas Pro 10 64 Bit
  • MXF in Vegas Pro 10 64 Bit
    Posted by Simon Feilder on July 26, 2011 at 10:33 am
    Hi there,
    I’ve recently got a new laptop with no firewire port and am having trouble getting footage from a DV tapes (shot on a Z1) into Vegas for editing.
    In lieu of being able to import the tapes directly into Vegas, I captured the footage on a friend’s AVID hoping I could simply plug the hard disk into my laptop and use the clips, which are in MXF format (which supposedly Vegas Pro can handle).
    Each clip is comprised of 3 files (presumably 1 video & 2 audio) but when I try and import them into Vegas it simply says “Warning: An error occurred while opening one or more files”.
    Am I missing a codec or should Vegas be able to natively import these files?
    thanks!
    Simon Feilder replied 15 years, 2 months ago 2 Members · 4 Replies
  • Nigel O’neill
    July 26, 2011 at 2:10 pm
    I can confirm that Vegas 9 and Vegas 10 pro have no problems importing MXF files. I would suggest that Avid is the problem here. Unfortunately I am not familiar with Avid, so I cannot suggest where he may be going wrong.
    If your laptop has an expresscard, you can get a firewire express card for it.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Simon Feilder
    July 26, 2011 at 2:33 pm
    I guess it’s Avid not playing nice then…?
    Frustratingly my brand new laptop (Dell XPS 15) doesn’t have an expresscard either… Not ideal.
    I may have to try and get Avid myself…
  • Nigel O’neill
    July 27, 2011 at 2:50 am
    Simon
    I don’t think Avid will solve your problems. Judging by some of the issues/questions being raised on this Avid forum, I would suggest that the MC Adrenaline/capture tool makes an absolute mess of what should be pretty straightforward.
    https://cstest.avid.com/forums/p/87776/498747.aspx
    Perhaps you need to search the Creative Cow Avid forum or submit your question there.
    https://forums.creativecow.net/avidediting
    As an aside, Vegas HDV capture typically gives you an m2t file. I have been given HDV MXF files off a Sony EX1 camera, but that was via the XDCAM Explorer tool.
  • Simon Feilder
    July 27, 2011 at 10:36 am
    I downloaded a 30-day trial of Avid MC5 and the MXF files open in that so it looks like I’ll be using it to edit this project….
    *spends the day learning Avid….*
