Activity Forums Apple Final Cut Pro Legacy MXF import to FCP7 ?
  • MXF import to FCP7 ?
    Posted by Brian Mclean on August 6, 2012 at 8:07 pm
    I got some footage what contains a folder called:
    }CLP{
    Inside is a bunch of .MXF files.
    Does anyone know what plugin I need to convert these to import into FCP7?
    Andrew Rendell replied 14 years ago 3 Members · 4 Replies
  • Jakub Zańczak
    August 6, 2012 at 9:03 pm
    Have You tried XDCam Transfer? I use to make .mov from .mxf but it was whe they were on XDCam disk. Maybe it will work with files fom hard drive.
  • Brian Mclean
    DOH!
    Premiere can open them native.
  • Brian Mclean
    August 6, 2012 at 9:04 pm
    Turns out the footage was taken from a Nanoflash device.
    After searching for a few hours, I found out Premiere can open it.
    Yikes
  • Andrew Rendell
    August 7, 2012 at 8:36 pm
    Just to be confusing, some Canon’s use MXF as well as Sony’s, but they’re not the same. I’ve got both manufacturers utilities on my system: for Sony MXFs it’ll be Import-XDCAM but if they’re Canon MXFs it’ll be Log & Transfer and select the format in the L&T preferences.
