Activity › Forums › Avid Media Composer › MXF import to AVID
MXF import to AVID
Posted by Daniel Addelson on July 24, 2007 at 9:26 pmAnyone know how to import MXF files into Avid Xpress Pro 5.6.4?
The files are on an external hard drive.Joan Baldó replied 14 years, 4 months ago 5 Members · 4 Replies -
Rhewitt
July 25, 2007 at 1:00 am1. Create a new bin for import.
2. Select the MXF Format in the Media Creation Settings Media Type tab.
3. Open the bin in to which you want to store the imported files.
4. Drag and drop the files to be imported in the bin. -
Adam Paez
January 28, 2011 at 1:18 pmI’ve tried this and it doesn’t work. The settings are the same and everything.
‘You cannot import this file into a bin.’
Patrick Larsgaard
June 8, 2011 at 7:50 amIf you are trying to import clean MXF files you first have to copy the files into the Avid MediaFiles/MXF folder. Here you can create a new folder with the date of the shoot. (From what I know you should not make a folder with a name longer than six numbers/letters and no form for signs), then in Avid go to Media Tool and select all project and the drive that your AvidMediaFiles folder is located (remember to have MASTER CLIP on in the Media Tool options) then the files will appear, just select all and drag them to your perfered bin. Avid will not generate new mediafiles in their own folder structur from 01 and so on. It will read from your folder structur. No transcoding or waiting and all the meta data is with the clips.
Sincer
Joan Baldó
May 19, 2012 at 3:24 pmThanks very much Patrick for such amazing tip. I have spent near two days trying to be able to use some external MXF that a client brouught me in an external HDD and I was becoming crazy!!
The way you explain you can locate and use all the available media inside the sistem
Thanks very much again!!
