Activity Forums Adobe Premiere Pro MXF import issues in Premiere CS5
  • MXF import issues in Premiere CS5
    Posted by Rachel Jenks on June 30, 2010 at 6:39 pm
    We recently updated to CS5 Master Collection.
    In Adobe Premiere Pro CS5, we are having difficulty importing mxf files. Premiere sees the file and imports, but then takes 2 hours+ to “render peak file”….then, takes upwards of 7 hours to render that file within the sequence….which seems incredibly long for only a 10 min. mxf file.
    Running on a PC, with Vista.
    I have done some looking around on the internet and see that others have had this problem as well. However, from what I can see, looks like no one has found a solution yet.
    Have any of you discovered a good workaround for working with mxf files in Premiere CS5?
    Rachel Jenks replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
