Activity › Forums › Adobe Premiere Pro › MXF Files and PPROCS3 Help
  • MXF Files and PPROCS3 Help
    Posted by Brieana Jennings on October 22, 2008 at 6:33 pm
    Hpxw9400
    4gb ram
    Matrox le
    Hello everyone I have a Big Problem with my PPCS3
    I am quite new to Ppro and need to understand how it uses memory. I can only work for a few minutes before my memory usage indicates that I’m at 75%. Then it crashes. I have an HD project that uses MXF files. The way I organize them is as follows: import, sort and put into a sequence. I then edit with this sequence. This is the same way I do it on Avid and I don’t have any problems. With Pro CS3I can only work for 15 minutes close the application and wait 7 minutes for it to load. Once loaded my memory usage indicates 55%. I have even broken my sequences down to under 6 minute as suggested by matrox. Clients don’t want to see their program broken up like this
    I must be doing something wrong
    What is the best way to work with MXF files?
    Vince Becquiot replied 17 years, 11 months ago 2 Members · 3 Replies
  • Vince Becquiot
    October 22, 2008 at 6:39 pm
    I don’t use a Matrox card (could be the issue), but Premiere should be able handle quite a large project with 4 Gigs.
    Anything else running at the same time?
    What’s inside the MXF, P2?
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
  • Brieana Jennings
    October 22, 2008 at 8:34 pm
    Footage shot on DVCPoHD 720p 24frames
    lightscribe, AVG Virus Protection, services icon,log me in remote software. Not much
  • Vince Becquiot
    October 22, 2008 at 8:46 pm
    I would absolutely lose the antivirus. Keep it mind it has to check each one of these huge files for viruses everytime you access them.
    You will also at least need a RAID 0 setup with 2-3 drives to get things running smoothly in HD.
    Also try this: https://www.pcmag.com/article2/0,2817,2253746,00.asp
    It will allow you to close all running tasks before starting Premiere.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
