Activity Forums Apple Final Cut Pro Legacy MXF File Importing into FCP 5?
  • MXF File Importing into FCP 5?
    Posted by Jason on February 14, 2006 at 5:00 pm
    Hello,
    I downloaded a few MXF (Panasonic HVX200) files to test out in FCP.
    The files are named ex. Flag.MXF.txt
    Can someone help me out? I would like to import this into FCP and edit it.
    Thank You
    JAson
    Shane Ross replied 20 years, 6 months ago 3 Members · 4 Replies
  • Shane Ross
    February 14, 2006 at 6:46 pm
    The only way I know of to import MXF files is from footage shot on a P2 card. They would have the suffix .MXF, and be a part of a whole bunch of other information. .TXT is a text file, in my experience.
    But, you can try…I guess. You need at least FCP 5.0.4 and QT 7.0.3, and you could try IMPORT>PANASONIC P2.
    But I doubt that will work. YOu need more information…and that .TXT tells me it isn’t an MXF file.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Joseph Bradley
    February 14, 2006 at 8:24 pm
    I thought that mxf files were from the new IMX format. if so then you can capture it using xdcam.
  • Jason
    February 14, 2006 at 9:30 pm
    Hello,
    Ya, I found out the files were uploaded wrong 🙁
    It seems they need to be in a contents folder also????
    Thanks all
    JAson
  • Shane Ross
    February 14, 2006 at 9:45 pm
    Yes, as CONTENTS folder, and in the same place a LASTCLIP.TXT file. Inside the CONTENTS folder you need: AUDIO, CLIP, ICON, PROXY, VIDEO, VOICE.
    Shane
    Alokut Productions
    http://www.lfhd.net
