Activity Forums Panasonic Cameras MXF File Import into FCP 5?
  • MXF File Import into FCP 5?
    Posted by Jason on February 14, 2006 at 5:07 pm
    Hello,
    I downloaded a few MXF (Panasonic HVX200) files to test out in FCP.
    The files are named ex. Flag.MXF.txt
    Can someone help me out? I would like to import this into FCP and edit it.
    Thank You
    JAson
    Jason replied 20 years, 7 months ago 2 Members · 2 Replies
  • Jan Crittenden livingston
    February 14, 2006 at 6:10 pm
    Unfortunately whoever posted the clips messed with the Contents folder. FCP will only recognise as Contents folder and all of the other things that go with. the video clips which would be in a folder under CONTENTS, called Video, and the name of the clip would be 002XY.mxf, as an example. But FCP woudl have to see the CONTENTS folder or it will never see the Video Folder, which means that it will never see the video clips.
    So you need to go back to the source and get the contents folder.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Jason
    February 14, 2006 at 6:24 pm
    Jan,
    Thank you! I will have to contact these people to see if they can re-upload the files.
    Thank you
    JAson
    I know of you via DVXUser 🙂
