Activity Forums Apple Final Cut Pro Legacy MXF 2:1 equivalent
  • MXF 2:1 equivalent
    Posted by Grant Walls on March 24, 2010 at 12:03 am
    Hi Guys,
    I edit promos and shit for TV. They want me to switch to FCP for some of it. We’ve been capturing from DigiBeta into Avid MC at MFX 2:1. What would be an equivalent format to capture in FCP.
    Output is SD PAL onto DigiBeta tapes. Broadcast on Australian TV.
    Cheers,
    Grant
    Rafael Amador replied 16 years, 6 months ago 4 Members · 5 Replies
  • Shane Ross
    March 24, 2010 at 12:17 am
    Uncompressed 10-bit. Or you can try the ProRes HQ for SD…that’s similar to the DNx codecs.
    Shane
  • Jeremy Garchow
    March 24, 2010 at 1:52 am
    For SD, I’d just use ProRes, not even HQ. 10 bit Uncompressed will create huge files.
    Jeremy
  • Grant Walls
    March 24, 2010 at 2:10 am
    Thanks guys. I’ll go with plain old ProRes. I understood that DigiBeta could only handle 8-bit anyhow. Is this the case?
    G
  • Shane Ross
    March 24, 2010 at 2:25 am
    Not sure what youmean that it can’t “handle” 10-bit. It’s just a video signal. A cleaner one than 8-bit. BetaSP is typically 8-bit.
    Shane
  • Rafael Amador
    March 24, 2010 at 5:23 am
    Digibeta is 10b compressed so from the SDI you will get 10b uncompressed.
    Prores is your best option (unless you can manage 10b Unc).
    If you record from any analog source (Component or Composite), 10b capturing will yields the best picture quality whatever the original source (VHS or HDCAM).
    Rafael
    http://www.nagavideo.com
