Activity Forums VEGAS Pro MVP 15 won’t run .net issue?
  • MVP 15 won’t run .net issue?
    Posted by Scott Francis on December 21, 2017 at 5:14 pm
    Hey All,
    Just downloaded and installed my MVP upgrade. Went to run and now I get this:
    Failed to initialize the common language runtime engine. Please install the .NET Framework (download is available from Windows Update).
    I am running Windows 10 Pro, everything is up to date Windows wise and I turned everything on for netframework 3.5 and 4.7 in my “turn windows features on and off.”
    Any ideas?
    Xavier (Scott) Francis
    Mind\’s Eye Audio/Video Productions
    Gabriel Meono replied 8 years, 6 months ago 3 Members · 5 Replies
  • Gabriel Meono
    February 28, 2018 at 6:22 am
    Same issue here, have you solved this?
    Vegas 13 and 14 work perfectly, and Vegas 15 refuses to work.
  • Scott Francis
    February 28, 2018 at 10:50 am
    I did get it resolved, but not sure how. I believe I found some resources by Googling….
    Sorry I can recall. I THINK I had to adjust some Windows 10 settings
    Good luck!
  • Francois Pénzes
    February 28, 2018 at 11:39 am
    Hi Scott
    Have you tried this fix from the Vegas forum ?
    https://www.vegascreativesoftware.info/us/forum/vegas-pro-15-build-177-general-discussion–108306/?page=11
    Here’s hoping that it’ll help.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    \’\’When the cutting stops, the editing begins…\’\’
  • Scott Francis
    February 28, 2018 at 11:54 am
    YES!!!
    That was the fix I used. I have had to reset my VST plugin settings numerous times for transport issues to, so this seems to help.
  • Gabriel Meono
    February 28, 2018 at 5:45 pm
    I’m my case I had to rename “C:\Program Files\Common Files\OFX\Plugins” folder.
    It seems Real Smart Motion Blur (RSMB5OFX) was causing the crashes.
    Thanks for posting that thread with the workarounds!
