Activity Forums VEGAS Pro MVP 14 Crashes Every Time I “Render As…”
  • MVP 14 Crashes Every Time I “Render As…”
    Posted by Scott Sullivan on October 7, 2016 at 3:50 pm
    Is anyone else experiencing this?
    Every time I go to render the thing crashes. However it was working fine yesterday.
    Scott
    Ole Kristiansen replied 9 years, 11 months ago 2 Members · 1 Reply
  • Ole Kristiansen
    October 7, 2016 at 4:28 pm
    I had the same problem until I tried to made a project using only the C drive, so I think Windows 10 Anniversary Update
    causing the problem – was better when I had installed Windows 10 Cumulative Update KB3194496
    “Microsoft has received a small number of reports of Windows 10 freezing after installing the Anniversary Update
    on systems with the operating system stored on a solid-state drive (SSD) and apps and data stored on a separate drive.
    This issue does not occur when starting Windows 10 in Safe Mode. If you are experiencing this issue, we will be providing
    updates to this thread…We ask for your patience while we continue our investigation and please check back on this thread for an update.”
