Activity Forums Maxon Cinema 4D Muzzle work like Maya
  • Muzzle work like Maya
    Posted by Dylan on April 7, 2005 at 9:33 pm
    Can CD4 do muszzle work like Maya? Talking animals with by animating the mouth, tongue, etc and adding back fur/hair to match? If so, in general terms, how would you go about it in C4D?
    cheers,
    Dylan
    Kiran Thapa replied 17 years, 5 months ago 3 Members · 2 Replies
  • Dann Stubbs
    April 8, 2005 at 12:13 pm
    sure why not?
    you would probably need shave and a haircut plugin for the hair – you may be able to get away with some workarounds for simulating the hair if very short.
    all you need is your source footage then animate your muzzle over it – then render out your muzzle with alpha and composite back in just like any other 3d app would.
    dann
    Dann Stubbs – dann@darkskydigital.com
    Dark Sky Digital – https://www.darkskydigital.com
    https://www.RenderKing.com Value Priced Cinema 4D Render Farm
  • Kiran Thapa
    April 19, 2009 at 5:19 pm
    I am using shave and haircut in maya for fur but it takes lots of time when render if there any solution for decreasing render in shave plz help
