Activity Forums Apple Motion Muzzle Flash CG effect in Motion 2?
  • Muzzle Flash CG effect in Motion 2?
    Posted by Spakuloid on August 9, 2005 at 7:35 pm
    Hey –
    anyone know if creating realistic muzzle flashes (gun shots from small caliber handguns) is something that can be done in Motion?
    Thanks.
    -Spak
    Noah Kadner replied 21 years, 1 month ago 3 Members · 2 Replies
  • Doyle Rockwell
    August 9, 2005 at 9:02 pm
    Hey Spak,
    While you can certainly try to roll your own, using shapes and gradients, I’ve gotten good use out of both Artbeats’ Gun Stock footage <https://www.artbeats.com/prod/product.php?pg=1&id=165> and DigiEffects Delerium’s Muzzle Flash filter <https://www.digieffects.com/products.shtml#DELIRIUM> .
    The biggest challenge with digital gunfire, assuming that it’s not in broad daylight, is faking the light flash on the surrounding objects. Some diligent roto and color correction can get you a long way on that stuff. Good luck!
  • Noah Kadner
    August 10, 2005 at 12:11 am
    Also the Motion collection from Particle illusion has some great muzzle effects.
