Activity › Forums › Compression Techniques › muxing with Transport Streams
  • muxing with Transport Streams
    Posted by Aj Epstein on April 21, 2005 at 1:27 am
    hi there!
    I’m wanting to export an HD MPEG 2 with it’s associated AC3 audio to a muxed file using the Transport Stream spec.
    I’m using Final Cut 4.5 and After Effects, and I know there is a Heuris plug in that does this, but does anyone know of a way to accomplish this without having to purchase extra software?
    The goal is to load this onto a Mediasonic sever.
    thanks!
    AJ Epstein
    Charles Simonson replied 21 years, 5 months ago 2 Members · 1 Reply
  • Charles Simonson
    April 22, 2005 at 1:46 pm
    Take a look at MPEG StreamClip. As long as your video and audio tracks have the same name, all you have to do is load the video track into the app and the audio will be automatically associated. Then select “Convert to TS…” and your transport stream will be built.
