Activity › Forums › Apple Final Cut Pro Legacy › Mutli clip editing ProRess 422
  • Mutli clip editing ProRess 422
    Posted by Roberto a Zavala on January 31, 2010 at 10:36 pm
    Hello,
    I did a music vid recently and i wanted to do a multi cam edit. I used the cannon 5d mark 2 and the panasonic hmc 40. both in 1080P. when i tried to edit the clips with the multi cam edit the footage lags and there is a green bar on the time line. i have done multi cam edits before, but not in HD. i tried to make sure my setting are correct. i’m thinking it’s the proRess codec. Does anyone have any insight?
    Rob
    please email me. i will probably forget to look for responses. takskmz@gmail.com
    also, check out an internet show i’m doing. thanks
    https://www.thegarybellashow.com
    Shane Ross replied 16 years, 8 months ago 2 Members · 1 Reply
  • Shane Ross
    February 1, 2010 at 3:41 am
    Multiple streams of ProRes requires fast drives. You’ll need a RAID of some sort when working with multiple streams of ProRes. eSATA like Caldigit VR, G-Raid 3. Or if you have a MacPro, then getting 3 more internal SATA drives and raid those together. Or look at external RAID cases from Maxx Digital or CalDigit or SOnnet.
    Shane
