Activity Forums VEGAS Pro Muting an audio track
  • Muting an audio track
    Posted by Steve Edwards on December 5, 2007 at 9:42 pm
    I am using a multicam setup with Vegas using Excalibur for the multicam part. I had (what I thought) everything lined up last night, and have been putting in the markers today, and noticed some echoeing on the audio. Evidentally everything wasn’t lined up a well as thought. If I muted the 2nd audio track and just go with the audio on track one, it is ok. Can I just mute that audio track before I do the last sequence (multicam button) in Excalibur, and then render, or will it copy the audio track anyway.
    Edward Troxel replied 18 years, 9 months ago 2 Members · 1 Reply
  • Edward Troxel
    December 5, 2007 at 9:52 pm
    Yes. You can either delete the track (if you don’t want the audio in the project at all), Click the “Mute” button on the track header, add a Mute envelope and set it to mute, add a Volume Envelope and set it to all the way down, drop the volume slider on the track header all the way down, etc…
    Edward Troxel
    JETDV Scripts
