Activity › Forums › Apple Final Cut Pro Legacy › muticlip angle arrangement / copy and paste
  • muticlip angle arrangement / copy and paste
    Posted by Derik Thadd on June 11, 2010 at 6:10 pm
    I edited a long multiclip sequence and now I’d like to change the way the camera angles are ordered in the viewer window for the whole timeline. I know I can command + drag the angles into whatever order I want but that only works for one clip at a time. Can I change the order of the angles in the master multiclip and then reconnect all the edits to the mater multiclip somehow so I don’t have to go into each and every clip one at a time?
    D thadd.
    Jerry Hofmann replied 16 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 11, 2010 at 7:00 pm
    I’ve never tried it, but maybe if you load the original multiclip in the Viewer and re arrange it? Maybe they’ll all rearrange when you select open again in the sequence…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
